"Transmission" Fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by OZ132, Jul 21, 2009.
  1. OZ132
    OZ132 Member
    170
    Northern Indiana
    Is there such a thing, in the Prius? Does it need to be checked/changed?
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    The transaxle has less than 4 quarts of Toyota type "WS" transmission fluid. It is suppose to be the life of the car fluid with no scheduled change interval. In the Gen 2 Prius, after some used fluid analysis, it was generally seen that changes at 60,000 miles was prudent.
    Wayne
    Batmobile 2010 likes this.
  3. tochatihu
    tochatihu Senior Member
    9,456
    3,654
    Kunming Yunnan China
    2001 Prius
    Following the major transaxle redesign for 2010, it would be great to get an early look at the fluid condition. I bet somebody in Huntsville AL will do that :)
  4. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Someone in Huntsville Alabama eh? Whats so special about my city? Nasa?:p
  5. bwilson4web
    15,932
    Welcome to PriusChat ...
    Do you like Vietnamese? Chinese? Beer?
    Perhaps you'd like to get together someday for lunch with the Huntsville bunch?
  6. tochatihu
    9,456
    3,654
    2001 Prius
    C'mon you guys - you can't get real Chinese food in Huntsville. However the city has several other strong points.
    DickyDck likes this.
  7. NASCAR Mike
    NASCAR Mike Senior Member
    83
    Richmond VA
    Is there a filter in the tranmission pan?
    Since there is less than 5 qts, I would change the ATF fluid every 20k. It's cheap insurance to keep everyting running well.
  8. bwilson4web
    15,932
    There is none discussed or shown in the SAE paper.
    It seems a little aggressive. Based upon transaxle oil testing, the earlier NHW11 and NHW20 appear to respond best to:
    • 30k miles - NHW11
    • 60k miles - NHW20
    It will take a little time to use transaxle oil testing to figure out the best schedule for the ZVW30. However, I plan to start testing my wife's ZVH30 along the following schedule:
    • 5k - samples of engine oil and transaxle oil to send off for testing. I'm expecting the first sample to show elevated Si levels and any early 'lapping' debris.
    • +2k, +5k, +10k, +20k, +50k - a semi-log scale to monitor viscosity and elements schedule.
    Right now, I've been waiting for the paper manual but if it isn't available by August, I may go with the electronic version.
  9. bwilson4web
    15,932
    Well you can but you have to get the 'special menu' and order in Mandarin. <wink>
  10. jestoy7
    jestoy7 New Member
    238
    25
    Jacksonville, FL
    Bob, I'm very interested in following your research. Any chance that you can begin a project thread? I'm on other car forums, and project threads are pretty neat and interesting and you seem like the perfect candidate! :D
  11. tochatihu
    9,456
    3,654
    2001 Prius
    Bob, don't order this:
    爱恋的妻子肺
  12. dcoyne78
    dcoyne78 New Member
    135
    has anyone done a trans fluid change on a Gen 3 at home, i.e. DIY?
  13. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I know from most Toyota designs, there is no dipstick. Once you drain it, you open a plug on the side of the transmission, and fill with a pump. The procedure (dumb as it sounds) is to fill until fluid starts coming out. Plug it up and away you go.
    Transmission fluid should be fine through >100K miles...
  14. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    I have yet to do mine... I'll be sure to send a sample for testing... (great, now I have to find THAT post. Rather slow on an iPhone)
  15. snijd
    snijd DIY or die
    243
    52
    PNW
    You might take a look at this and determine for yourself the merits of an early fluid change. I'm a believer. Based on numerous analysis results, WS fluid doesn't last anything close to 100,000 miles, in either a Gen II or a Gen III car.
  16. pjksr02
    pjksr02 Active Member
    532
    226
    Connecticut
    Just to update everyone, Eneos has just released a new ECO-ATF, which meets Toyota WS:
    ENEOS has introduced its next generation Automatic Transmission Fluid, the ECO-ATF.
    ENEOS ECO-ATF is an ultra-low viscosity "multi-vehicle" transmission fluid that is compatible with ALL Japanese vehicles equipped with an automatic transmission (excluding a CVT transmission). This includes Toyota's WS (World Standard) transmission fluid.
  17. dcoyne78
    dcoyne78 New Member
    135
    I am assuming you mean a 2010 Prius? If you have not changed the fluid on your 2004 it's only $60 at the dealer or any competent mechanic can do it. It is too bad that it is not in the maintenance schedule for normal service, no fluid is good forever.
  18. fobac125
    fobac125 Junior Member
    Tumwater, WA
    I changed my transmission fluid today and it was definitely in need. Old compared to new fluid color was unbelievable. At any rate, something happened that suprised me and I'm wondering if this is normal. When I loosened the fill plug first, it released some pressure through the release of air which I could hear hissing. I was not expecting this, but wondered if this was normal.
  19. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    What was the mileage on the odometer? When I did ours at 30K and 90K there was no detectable pressure release as you described.
