Troubleshooting Prius old style way with only multimeter and spanners
Discussion in 'Gen 2 Prius Technical Discussion' started by Lib, Apr 14, 2023.
  1. Lib
    Lib Junior Member
    27
    Zambia
    am working on a prius 2005 which has been flashing the ready indicator for one second but not running.l measured all cells and found 1 dead 0V and 4 reading 6.26 V and the rest 7.3V. I had already bought 3 cells reading 7.6V because the last scan by a scan owner showed 3 cells fault.l replaced the 0v cell and the other 2 which was reading 6.26v of the 28 cells.l charged the remaining 2 reading 6.26V but when voltage reach 7.6V, voltage drops on its own to 6.6 first charge, second charge 6.8 while the rest are above 7.3V.The car is still not starting the total voltage surprisingly is not steady,its giving random figures 193V,35V .Now with only the multimeter and spanners what can l do to make car run?
  2. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Where are you taking your reading from? Did you plug the orange disconnect all the way in?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Any of the modules dropping below 7.2 should be replaced.
    It also sounds like your wire harness with the voltage sensing tabs is very likely faulty (cracked tabs or wires) or you have corrosion issues on that plug or in the ECU socket. These are all very common problems with the Gen 2.
  4. Lib
    Lib Junior Member
    27
    Zambia
    yes i did plug all the way.was measuring between those two cables in the picture
  5. Lib
    Lib Junior Member
    27
    Zambia
    can you show me in the picture l just sent
  6. ChapmanF
    16,943
    If you will not use any tools but those, the problem may be very difficult or insoluble.
    From the last scan by a scan owner, did you get any more details that you could post? What trouble codes were present?
    How difficult is it to obtain a scan tool in Zambia?
    I was tempted to use the barometer story: take the multimeter and spanners to someone who has a scan tool, and speak to them as follows: "here I have a very fine multimeter, and if you will allow me the use of your scan tool to diagnose my car, I will give you this multimeter."
    But I thought better of it, because you might still need the multimeter.
  7. Tombukt2
    Tombukt2 Senior Member
    11,555
    2,028
    Durham NC
    It's basically a 211 volt system . Which at present time of your reading you do not have so you may need to get up near that and then I'm not sure what you're meaning by the car not starting You mean it won't ready The green light on the dash? When you say won't run what's not running The car goes forward and backwards but you don't hear the gas engine coming on? Usually if you can get it into gear and you start backing up the engine will kick on with him like 13 seconds or something It's just the nature of the beast unless your battery's brand new and fully charged and all of that it's going to start almost immediately after throwing it into reverse to back out and get ready to go Tell my car would do this with a completely failing hybrid battery it just ran all the time the engine and the fan in the back by the battery was on all the time The minute you push the start button to get it ready the fan came on and then the engine came on about the same time the fan came on and never shut off and even then I was getting 39 mi to the gallon so not huge complaints just weird here in the engine running all the time for about 5 days.
  8. Lib
    Lib Junior Member
    27
    Zambia
    Thanks for the info,will try to charge the 6.8V cell to see if the can hold above 7.3V,l had this car since 2012 done over 200,000km,the ready indicator green one shows that the car is ready to move either in EV mode or on engine.
  9. Lib
    Lib Junior Member
    27
    Zambia
    Last time l got the P3030 P3000 volts .It couldn't help much. Need an advanved scanner.l have a wifi scanner it doesn't pick anything in HV system using Torque or Dr prius. l hear the bluetooth ones are able
  10. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
  11. ChapmanF
    16,943
    Are some of the other systems reviewed in this thread available there?
  12. Lib
    Lib Junior Member
    27
    Zambia
    yes l use torque pro and dr prius on android
  13. Lib
    Lib Junior Member
    27
    Zambia
  14. ChapmanF
    16,943
    There are also other systems reviewed in that thread. Some of them will give you more information than those can.
  15. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Did you actually go through that workup step-by-step?
    Random swinging voltage may be related to breaks in 'frame wire #2' and corrosion at HV battery ECU pins and #2 connector.
    2010moneypit? likes this.
  16. Lib
    Lib Junior Member
    27
    Zambia
    Hi guys so l replaced the two cells which where under 7V,while doing that l cleaned the corrosion in the HV battery connectors and pins.
    The Ready batery came back on without flashing.L run the car for two days and the ready Indicator flashed got it On after three trial.is the same problem (Flashing Ready Indicator) coming back again?
    l made Four Obdservations
    1.There was a mild sound of sparks at the back when driving but not when idling.(could it be the two terminals l couldnt torque because of damaged threads?)
    2.The Hv fan is continously runing.it used to stop sometimes
    3.There is error indicators on the dashboard Red Triangle, check engine and another orange looks like a brake symbol.
    4 .the Dashboad is no lighting up when turning ON only after some trials
    l know many will ask for a scan so l got a guy with the launch scanner and attached is the report.
    How can l fix esp the major problems in layman term?
  17. bisco
    50,803
    you need to replace the stripped terminals and torque everything properly, you're in immanent danger of an explosion, and burning your car down along with any occupants and anything nearby.
  18. Lib
    Lib Junior Member
    27
    Zambia
    Thanks will do that because running it again.could that be the solution to the other codes?
  19. bisco
    50,803
    it's possible. you need to get the battery shipshape before proceeding. have you considered dr. prius?
  20. Lib
    Lib Junior Member
    27
    Zambia
    will consider when l get a bluetooth OBD2 scanner the one i have it uses wifi
