Trying to put together the left front fender after an accident
Discussion in 'Prius v Main Forum' started by Noelle369, Sep 21, 2024.
  1. Noelle369
    Noelle369 New Member
    2013 Prius v wagon
    I ordered a new fender and headlamp assembly. I can't get it to fit back together. I am a female electrician and not a mechanic and thought I would try to fix the car myself. The headlamp assembly is supposed to slide in on the bottom but a part of the body it in the way and the cross support doesn't reach on the topside. Can anyone help? Am I missing a part? I even bought a new side retainer.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,285
    5,657
    Texas Hill Country
    A longer shot would help showing the front end. If the bumper cover is on you have to partially remove it. The Prius v has a different headlight assembly than the more common hatchback.
  3. Air_Boss
    Air_Boss Senior Member
    4,124
    1,146
    New Yawk
    Is it possible that substructure was damaged in whatever caused you to make the fender replacement?
  4. Noelle369
    2013 Prius v wagon
    The entire bumper is removed. I did find out about the headlamp assembly being different. I had to order it twice to get the correct one. ): Thank you.
    Danno5060 and Air_Boss like this.
