Type of Fuel
Discussion in 'Gen 3 Prius Technical Discussion' started by Steverit, Apr 22, 2011.
  1. Steverit
    Steverit New Member
    Katy, Texas
    I have a new Prius 2011 THREE. I know Toyota recommends 87. What do most of you run out there. I really appreciate your help
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    87 since there is no benefit spending more for higher octane. That holds true for the majority of us.
  3. GBC_Texas_Prius
    218
    38
    gbc texas
    87 octane. Back in the ol' days (20 years ago?) when you could hear an engine knock, it was when you were putting the petal to the metal. With the Prius, the high torque electric motor kicks in helping the ICE out. I'm not worried about octane because I know the electric boost takes most of the torque strain off the gas engine.
    50,812
    eighty seven
  5. Mark57
    2,945
    2,738
    OK
    87 all the way.
  6. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    87, though I did spend 20 extra cents a gallon today to get ethanol free up in Greenville SC.
    I figured why not, thats what our normal gas here costs.
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I use regular (lowest octane--not sure what it is in CA).
  8. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Regular, which is 87 here, but could be 86 or 85 west from Mississippi.
  9. RRxing
    RRxing Senior Member
    2,528
    1,803
    NEPA
    87 octane (Regular)
    E10 (No choice)
  10. oldfolkswagen
    oldfolkswagen New Member
    MT
    Well, I'll get sucked into this discussion:
    At work I drove a 2005 Buick AWD van with a large v6 engine, and averaged between 5,000 and 6,000 miles a month. I have had time to 'experiment' with octane ratings. For two months I used premium grade gasoline and averaged 21.8 mpg. For two months I used the lowest grade and averaged 21.9 mpg. My trips were mostly highway miles with about 5% city driving. I cover the state from corner to corner so all my trips were about the same. I used mostly the same brand of fuel. The weather conditions were about the same when I 'experimented.' I drove fairly conservative with the work car just as I would with my own car.
    I saw no real difference between mileage and octane rating. The van must have compensated for the octane and adjusted accordingly. I noticed no knock on any of the gasoline changes.
    JUST my 2 cents worth.
    So octane 85 is my choice from here on out.
  11. oldfolkswagen
    MT
    I agree with this assumption. The only time you would get spark knock from a low octane fuel would be in a full "under load" condition. That's the brilliancy of having an electric motor to do the hard work, and having the ICE as the backup.
  12. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    87 makes sense, Toyota recommends it . Higher octane does not give more power as the Fuel Companies used to claim-back in the day.
    octane ([​IMG]k[​IMG]t[​IMG]n[​IMG]) Any of several hydrocarbons having eight carbon atoms connected by single bonds. It is commonly added to gasoline to prevent knocking from uneven burning of fuel in internal-combustion engines. Octane is the eighth member of the alkane series. Chemical formula: C8H18.
    The American Heritage® Science Dictionary Copyright © 2005 by Houghton Mifflin Company. Published by Houghton Mifflin Company. All rights reserved.
  13. Maine Pilot
    Maine Pilot Senior Member
    166
    504
    Saco, Maine
    Wonder if the ICE has an "anti-knock" sensor? Most cars do nowdays.
  14. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    I can only get gas with 10% ethanol in California. Did you notice any difference in FE with the ethanol free?
  15. Tideland Prius
    16,402
    87. Although Bob Wilson did suggest using 89 if you're going on a road trip. His lengthy discussion is somewhere on this site with plenty of graphs.
  16. amorris
    amorris Junior Member
    57
    Dallas TX
    Dealer told me 87, so 87 it has been for over 9000 miles. Averaging right at 50 mpg.
  17. REV-X
    REV-X New Member
    Fredericksburg, Va
    This car is made to run on 87, anything more would be a waste IMHO seeing how this is a fuel saving hybrid and not a performance vehicle of any type.
  18. jamesa53
    jamesa53 New Member
    74
    Indiana
  19. ETC(SS)
    6,841
    I use 87.
    Just for fun, I've run a couple of tanks of E0 through my car and I didn't notice a difference that justifies the added price....maybe 2MPG.
    I'll give BW's advice to use 89 for longer trips a read...but I haven't yet seen a reason to use anything but the cheap stuff.
  20. carpedal
    carpedal Member
    37
    58
    Centreville, VA
    An additional contraversy is using a Top Tier manufacturer. When auto makers first started with port injection and all aluminum construction, they found the intake area around the valves building up with deposits. The auto makers response was to band together to create a higher standard. Here is an excerpt from Wikipedia both pro and con.
    According to its marketers, all vehicles will benefit from using Top Tier Detergent Gasoline over gasoline meeting the basic EPA standard. Deposits will reputedly be minimized on fuel injectors, intake valves, and combustion chambers.[7]
    New vehicles will supposedly benefit by keeping their engine clean and running optimally, older vehicles may benefit with increased engine performance and prolonged vehicle life.
    Using this gas is purported to have the following benefits over gasolines just meeting the EPA standard:
    Improved fuel efficiency
    Reduced driving upsets (rough idle, stalling and surge)
    Improved acceleration
    Increased engine power
    Reduced emissions
    Criticism
    Several car manufacturers believe that using top tier detergent gasoline has an impact on all vehicles. Some critics believe that using top tier detergent gasoline is only critical on high-end vehicles; otherwise, using engine cleaner every 100,000 miles should clean up any carbon buildup.[8][9] Other critics say that top tier detergent gasolines cause little or no decrease on the amount of buildup on a car's engine.[10]
    Before a standard used was the BMW Unlimited Mileage Test. Arco claims to meet this. BMW now mentions Top Tier gas in its owner's manuals but not the unlimited mileage test. Arco is not listed as a Top Tier gas.
    Ford recommends BP fuels and mentions it on Ford car gas caps. BP is not on the Top Tier gas list.[11
