Featured UK’s First Residential Avenue Fully Converted To Lamppost Charging
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Mar 21, 2020.
  1. Tideland Prius
    16,408
    Full Article and Press Release
  2. El Dobro
    El Dobro A Member
    7,071
    3,258
    Now, they just have to keep them from being ICE'd.
  3. mikefocke
    3,869
    1,744
    Sanford, NC
    How many will trip over the cords? Bet they are low charge-rate. Our town installed several, I see the same cars parked using them every time I go by there.
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Remember their normal is 220v.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,588
    near Brisbane, Australia
    I think it's 230volt? Australia is 240 and I think much of Asia.
  6. El Dobro
    El Dobro A Member
    7,071
    3,258
    In England the standard voltage is 230 V and the frequency is 50 Hz.
  7. alanclarkeau
    7,045
    7,588
    Interesting - I now read that some of Australia has moved to 230 volt - but not Queensland - mine is reading 244.6 at this present moment.
    Apparently, but 1 July it should be nominally 230v - but within the "allowable range between 216 volts and 253 volts."
  8. Trollbait
    12,254
    Much of Europe can do a "Level 3" AC, if the car has the right charger. But these are overnight chargers intended for the people without a home charger.
    I think US electric to street lights is higher voltage than residential; I want to say 207V.
    kenoarto likes this.
  9. El Dobro
    El Dobro A Member
    7,071
    3,258
    From what I've found, the street light voltage is either 110 or 220, depending on the neighborhood.
    kenoarto and alanclarkeau like this.
  10. Trollbait
    12,254
    I might have been thinking of lighting in commercial buildings. The discussions here can merge together.:)
  11. hill
    8,588
    weird - but 277V is pretty common in the U.S. as well. 440-480v 3 phase, Line to neutral gives you 277V and that way, the location (typically commercial) doesn't have to install a separate transformer.
    telmo744 likes this.
  12. Lee Jay
    Lee Jay Senior Member
    5,850
    4,029
    Westminster, Colorado
    That's how it is where I work.
    Right outside my building is a 1MVA 13.2kV to 480V ine-to-line transformer (277V line-to-neutral). Every light in the building and all our street lights run on 277V.
    To provide 120V for the offices and convenience outlets, there are several 480V to 208 line-to-line (120V line-to-neutral) transformers. One of those runs our 16 charging stations at 208V. That means my Prime charges at 3.2kW (208V * 15.6A actual) instead of the theoretical 3.8kW (240V * 16A).
    Another interesting thing is that we have an experimental system that minimizes demand charges. It actually measures building load and, when the building load goes up, the available collective charging power goes down. It starts at 30kW shared among 16 chargers but when the building load goes up it can drop to 25kW or 20kW. It won't charge your car slower than 8A but it will modulate that on-and-off if needed if lots of people are charging and the building load is high. I've seen it charge at 8A for 50% of the time - slower than L1! You input how much you need and when you need it and the system tries to meet that request, including the requests of everyone else.
