unsafe stearing feel always correcting back and forth at 65 mph
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lewis, Sep 1, 2009.
  1. lewis
    lewis New Member
    vista
    My 2010 Prius feels squirrely on the highway at higher speeds (50-70) mph. I am continually having to correct as if the wind is blowing hard when there is no wind. It is not like tire pull or alignment. I have 2100 miles on the car and so far it is not stablizing. Any others had this experince?
    Thanks
    lewis
  2. bobutler
    bobutler New Member
    Tennessee
    Lewis: I just started driving a 2008. I feel the same way many afternoons on the interstate driving home. I have begun to attribute this feeling in large part to being in a new car. I drove a very stable Subaru Outback for 10 years - it had all-wheel-drive, wider tires and 22 mpg. So, I get in this jelly bean with tiny tires all blown up to about 42 psi and head down I-65 - I think I feel every crosswind, headwind and vehicle slipstream out there. It's not boring! And I'm getting great gas mileage. I think I will learn to live with it.
    I will also send it in for an alignment check soon, just to be sure.
    Bo
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Mostly it is the tight steering. The electrically assisted power steering has nearly zero deadband, meaning every little input gets sent to the wheels, producing what is called pilot induced oscillation. As you get more used to car, this tendency will diminish.
    Obviously you want to check things like tire inflation and tread.
    Tom
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    +1 what qbee42 said.
    The "fly by wire" steering, on the Gen II anyway, has virtually no
    tactile feed back. The steering wheel does not push when you make
    minor corrections. So, you subconsciously turn the wheel a little more
    to get some reaction inthe wheel and to your hands. (Did you know
    that the steering wheel is not directly conected to the steering gear?
    I'm not kidding, it's all electronic, as are the brakes and "gear
    selector.")
    I'd say you have to relearn making small corrections on visual clues
    alone. I't not that difficult, but is has to be a conscious effort. Once
    you get some on the job training, you'll be able to relax and start to
    enjoy the may little niceties of the car.
    Hope this helps.
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    This is posted under Gen II, but is about a 2010. I bet you get even more folks who tell you about the Gen II steering and few 2010 owners replying.
    [Edit: and now they have moved it]
  6. richard schumacher
    7,664
    1,042
    United States
    Betcha the feeling goes way in a month or so.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Sorry, this is not true. Try turning your steering wheel when the car is shut down, I bet with effort the wheels will turn and the steering will be very heavy. The Prius has electric power steering. Electricity does what hydraulic oil does in other cars but the system is otherwise the same as other cars. there is no slack in the steering, it is very tight.
    Best way to handle it, relax your grip on the steering wheel and allow some slight variations to course while remaining in your lane. You will find your car tracks straighter.
    If this doesn't do the trick a 4 wheel wheel alignment at a reputable tyre dealer of Toyota dealer may help.
  8. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    I just did a 240 mile drive at 65/75 mph and had no problem at all with steering, but i'm not the kinda driver that puts a strangle hold on the wheel. There was some short bursts of speed up to 95 mph as i was passing some slow movers. I use a pretty light touch and always have. Even when doing some racing. But i'm to old to do much racing anymore. :(
  9. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Lewis,
    I had exactly that problem with my 2005 and it turned out to be alignment. In my case it was very hard to find because it was the rear axle that was toed out to far. Hopefully yours will be easier to find, get an alignment done right away and that might fix it. Toyota should do the alignment under the warranty.
    My car was all over the road even with no wind. It would show up at speeds in excess of 60 MPH, at slower speeds it was usually OK. Several of the Gen 2 cars seemed to suffer from this. One of the hardest and most frustrating things was that no one would believe I had anything wrong, unless of course they had experienced it themselves. After it was finally fixed it was literally like a different, and far better, car.
    My saviors turned out to be Galaxee and DH from this site, he was a Toyota Hybrid tech at the time and had seen the problem before. They helped me find what was wrong and were able to tell me how to fix it. Thanks for friends on PC.
    Edit: When you have the alignment done be sure to get a copy of the readings, it's just one page and it shows as found and as left readings for the alignment parameters front and rear.
  10. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Try making your corrections very slowly, and that'll help give
    you the purely-visual feedback path the Prius needs. And if
    you're driving with one fist on top of the wheel like a lot of
    people seem to do, that's inherently unstable...
    _H*
  11. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    This has been discussed in a few threads--it's probably tramlining.
  12. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    My new 2010 Prius-III seems to steer well at all speeds, even slightly more or less than the speed limit.
    At 40 psi (as delivered by the dealer) I do feel cross-winds easily, but the steering is steady and smooth.
