Upsizing to 17" wheels
Discussion in 'Gen 3 Prius Technical Discussion' started by yamisoshi, Nov 2, 2010.
  1. yamisoshi
    yamisoshi Junior Member
    64
    Meridian, ID
    This is probably a stupid question, but I was wondering for those that have up-sized their wheels from 15's to 17's (same as OEM size 215/45/17) if the wheel-wells/ground clearance have gone up?
    I want to go up in size to use the 15's with snow tires, but don't want to spend the extra $$$ to lower the car ... yet.
    Thanks in advance!
  2. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    The different wheel/tire sizes on the Prius are set so the outside diameter is the same. No or minimal difference in ground clearance.
  3. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    Im on 215/45/17 alloy during the summer. In winter I use 195/65/15 steel. The difference is a quite small, no problem at all.
  4. yamisoshi
    64
    Meridian, ID
    That's exactly what I was hoping to hear. Thank you very much. :) :) :) :) :)
