USB Charger
Discussion in 'Gen 3 Prius Accessories and Modifications' started by tzh, Aug 11, 2016.
  1. tzh
    tzh Member
    105
    Maryland
    I have installed a dual USB charger. I simply replaced the cigarette lighter (I had to enlarge the hole a tiny bit). You can make a new access hole if you like to keep the C lighter. The installation took about 20 mins.
    It has two 5V 4.2A USB ports and also show the voltage.
    Also need couple of wire connectors .
    Dylan Doxey, Ramirezja, RMB and 2 others like this.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Looks good. Putting 1 of these in the back of the center console would be great for rear passengers
    iPhone ?
    HelloHybrid and Starbrand like this.
  3. tzh
    tzh Member
    105
    Maryland
    Yes indeed. I am thinking to add one later :)
    sfv41901 likes this.
  4. andino
    andino Senior Member
    746
    550
    San Jose, CA
    Looks great! Though I'm pretty sure that those ports will be 2.1A each (4.2 total) since the type A port is only good for 2.4A at 5V.
  5. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    Where did you get it? Did you have to remove the lighter sub panel? How?
  6. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
  7. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    I just did this mod, highly recommended!
