Using Autel DS708 Scanner : how to clear ABS codes | Help needed
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Jojo_Mass_2_Ga, Feb 16, 2025.
  1. Jojo_Mass_2_Ga
    Jojo_Mass_2_Ga New Member
    Atlanta
    2014 Prius v wagon
    Good morning y'all
    I have a 2014 Prius V Five with the ABS |Brake Booster | Accumulator issue
    Cobb county Toyota quoted me $4600 that I dont have to remediate the problem
    I have access to an Autel scanner DS708, it reads 4 codes; however, it does not erase them;
    does anyone know how to use the scanner to clear the codes without replacing the parts in the meantime?
    I simply want to get rid of that pesky beeping sound while the Christmas tree is lit on dashboard
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,285
    5,656
    Texas Hill Country
  3. MAX2
    MAX2 Senior Member
    1,333
    415
    101
    Third planet from the Sun
    What codes does Autel scanner DS708 give?
    Can you write to us to understand if they are related to the brake system or if there are problems in other systems?
  4. rjparker
    9,285
    5,656
    Texas Hill Country
