Vanity lights not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by santoro1, Jul 26, 2006.
  1. santoro1
    santoro1 New Member
    132
    Just got my magnetic gray #4 last night...Noticed everything seems to work except the two small vanity lights above the sunvisors...Tried following user manual's idea of putting them up, then down and then trying the lights, but neither work. All other lights that I can see are working...Any ideas.
  2. marjam
    marjam Member
    220
    Silver Spring, MD
    A resent post gave the following information. You must have the mirror door open on the visor, the switch to "on" and then they will light only when the visor is at the angle you would use to see in the mirror. Put the visor toward the windshild or the roof and the light goes out. If you have tried this and it still doesn't work you must have gotten dead bulbs!
    Hope you enjoy your new car!
  3. ttayloriii
    ttayloriii Junior Member
    <div class='quotetop'>QUOTE(ajs @ Jul 26 2006, 08:36 PM) [snapback]292909[/snapback]</div>
    YES! Mine did the same thing. Open the little mirrors on the visors and the vanity lights should work.
  4. Tideland Prius
    16,402
    Yup. I mean, it's smart enough to know you only need the light when you use the mirror.
  5. darelldd
    6,057
    389
    Northern CA
    Or in other words... Actually USE the mirror, with the light on... and suddenly they'll work. If not, you probably need LEDs. :)
  6. glenhead
    glenhead New Member
    166
    Also, this is another lawyer-imposed restriction - the driver's side vanity light will not come on unless the car is in park. How the heck are you supposed to get an eyelash out of your eye at 70mph in rush hour traffic if you can't use the vanity light? Holding a flashlight in your mouth (while steering with your knees so you can use both hands (one to hold the eyelid up while you fish out the eyelash with the other hand)) makes you drool, and that can make a mess on the cellphone tucked in your shoulder... :lol:
  7. santoro1
    santoro1 New Member
    132
    <div class='quotetop'>QUOTE(darelldd @ Jul 27 2006, 03:36 AM) [snapback]293047[/snapback]</div>
    Thanks everyone...real simple...Put the visors down, turned on the switch AND opened the mirror cover and presto...they worked...Such a simple fix, but very hard if you don't know it....Thanks again.
  8. marjam
    marjam Member
    220
    Silver Spring, MD
    <div class='quotetop'>QUOTE(ajs @ Jul 27 2006, 12:27 PM) [snapback]293225[/snapback]</div>
    You can leave the switch on all the time. I didn't know that the driver's only worked in PARK. Guess I won't be able to shave during my commute <_<
  9. Starfall
    Starfall New Member
    215
    <div class='quotetop'>QUOTE(marjam @ Jul 29 2006, 03:28 PM) [snapback]294367[/snapback]</div>
    Not so bad. Think of all those "close shaves" you'll avoid.
  10. richard schumacher
    7,664
    1,042
    United States
    <div class='quotetop'>QUOTE(Starfall @ Jul 29 2006, 03:32 PM) [snapback]294368[/snapback]</div>
    Tee-hee! Thanks for th' best chuckle o' th' day.
