Vehicle safety control feature?
Discussion in 'Gen 2 Prius Main Forum' started by Dionna M House, Jul 4, 2005.
  1. Dionna M House
    Dionna M House New Member
    Hey Everyone,
    I just order my Prius 05. I chose the middle model, that comes with foglights and Vehicle safety control. My question is about the benefits of VSC. How important is it?
    dionna
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Dionna:
    VSC (Vehicle Stability Control) is one of those things you may never need. But if you ever get yourself into a situation, say to swerve around something on the Interstate, it may very well save your life and your car.
    Up to the limits of tire traction, it really will stop any slides or spins.
    Jay
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I think you are talking about Vehicle Stability Control which Toyota calls Vehicle Skid Control.
    Here is a breif description:
    Toyota developed a VSC system that relies on electronics to help control a vehicle when a loss of traction is imminent.
    VSC senses the onset of traction loss and helps the driver stay on track. This is achieved via the system's ability to reduce engine power and to control the brake actuator. While other Toyota systems such as antilock braking systems (ABS) and traction control (TRAC), help prevent straight-line skids, VSC helps avoid the loss of control up to the physical limits of the traction available under lateral skidding conditions.
    VSC harnesses ABS and TRAC sensors, actuators, and computer electronics to help the driver avoid vehicle skids and spins. Using input from four wheel-speed sensors, a directional sensor, a deceleration sensor, and a steering wheel angle sensor, the VSC computer uses engine throttle control and individual wheel braking to help counteract skidding and spinning. VSC also includes a slip indicator with a warning sound and light to alert the driver that the tires are about to exceed the grip limit.
  4. Dionna M House
    Yeah that is what I meant. :lol: I so happy to have found the chat here, because, car talk is not really my forte. :oops: I guess I made the right decision on the package. The dealer said I can change my mind if I wanted.
    I'm new to the forums here and will be looking at the various topic and utilizing the knowledge here on the list.
    Thanks again,
    Dionna
  5. ceric
    ceric New Member
    1,114
    Fremont, CA
    VSC is one of those things that you may never use it, but if you should need it, it may save your life. I have been bailed out by the VSC in my BMW twice (e.g to avoid a big piece of tire tread on highway). VSC works wonder in emergency maneuver, over-speed turn on low traction surface (rainny, snowy). With it, it is hard for you to even on-purposedly induce a spin of your vehicel. For driving fun, you need to turn it off, but I don't see why you would want to do that in a Prius...
  6. bobc
    bobc New Member
    361
    Durham, NH
    Consumer Reports states that every car should have VSC and that consumers should go out of their way to purchase a car with this. They are real big proponents of this safety feature...
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    even the chairman for GM admits the VSC will be more importrant than seat belts and will be the next required safety feature
  8. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    VSC=ESC: Electronic Stability Control. This may help when searching for non-Toyota information.
    Basically prevents you from fishtailing.
  9. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    hmm. they look like trees to me...
  10. Tideland Prius
    16,559
    <div class='quotetop'>QUOTE(seasalsa\";p=\"104040)</div>
    Actually, ours is the Vehicle Stability Control. Vehicle Skid Control is the previous version on 2002/2003 cars and older.
  11. seasalsa
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(Tideland Prius\";p=\"104380)</div>
    [/b][/quote]
    Could be!
    However they must have failed to inform the ESC Coalition as they still list all 2005 Toyotas as having Vehicle Skid Control.
    http://www.esceducation.org/about_esc/esc_..._vehicles.shtml
    You will notice that each manufacturer has their own name for VSC.
  12. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Acura - Vehicle Stability Assist (VSA)
    Audi
    Chrysler
    Jeep
    Dodge
    Kia
    Mercedes
    Saab - Electronic Stability Program (ESP)
    BMW
    Jaguar
    Land Rover
    Mazda
    Mini - Dynamic Stability Control (DSC)
    Buick
    Cadillac
    GMC
    Pontiac
    Saturn
    Chevrolet - StabiliTrak
    Corvette - Active Handling System
    Ford
    Lincoln
    Mercury - AdvanceTrac
    Honda - Electronic Stability Control (ESC)
    Infiniti
    Nissan - Vehicle Dynamic Control (VDC)
    Lexus
    Toyota - Vehicle Skid Control (VSC)
    Mitsubishi - Active Skid and Traction Control MULTIMODE TM
    Porsche - Porsche Stability Management (PSM)
    Subaru - Vehicle Dynamics Control System (VDCS)
    Volkswagen - Electronic Stabilization Program (ESP)
    Volvo - Dynamic Stability and Traction Control (DSTC)
    But, as best I can tell the Prius actually has VSC+ which also somehow involves the electronic steering, which can't be done in a normal vehicle.
    Quotes about it -
    "new version of the Vehicle Stability Control system, called VSC+, operate through an electric/electronic circuit. A central electronic brain, the Skid Control ECU, co-ordinates all these systems to create perfect synergy between them. The VSC+ works in conjunction with the electric power steering system in emergency situations, making it possible to improve vehicle reaction times and so help avoid or minimise the impact of accidents."
    "Toyota Prius also intends to set an example in the area of active safety. For this reason, it is fitted as standard with features that are unique in the class: 'by-wire' Electronically Controlled Braking (ECB2), Electric Traction Control (E-TRC) and the advanced Vehicle Stability Control Plus (VSC+).
    The innovative 'by-wire' ECB2 braking system uses brake pedal-activated electronic sensors to create braking feel and control the braking hydraulics. It not only generates higher hydraulic pressures than conventional systems, but it is also 17% lighter.
    The Prius is the world's first car to be fitted with Electric Traction Control (E-TRC). The system controls wheel slippage via ECB2 and the high-torque electric motor element of the Hybrid Synergy Drive. E-TRC is so quick in counteracting the incipient skid that the driver often won't even be aware of an intervention, nor will he or she hear the tyre squealing that is often associated with wheel spin.
    Interconnected with ECB2 and E-TRC is Vehicle Stability Control Plus (VSC+) which is the world's most innovative stability control system. It works with the electric power steering system (EPS) to add steering torque assistance to the conventional stability control system, helping the driver get the most out of the car's performance potential by avoiding stability-threatening situations."
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    very imformative tempus, although not specifically Prius related, might be a good candidate for FAQ page
  14. Tideland Prius
    16,559
    The program that combines TCS/VSC/ABS with steering is Lexus' new VDIM pr Vehicle Dynamic Integrated Management. Along with VGRS (Variable Gear Ratio Steering) aka Active Steering, it makes minor steering corrections when cornering or going in a straight line to minimise the correction that the driver has to make when there's strong crosswinds or simply if one side of the vehicle has more/less traction than the other.
  15. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    Hi Donna,
    You ordered a Package #4 (AM) . . . which I have and like to call a “Safety Model.â€
    From personal experience with experimenting with the VSC in an unplowed empty ski resort parking lot: I could not make the car go out of control . . . even though I tried several times. I BELIEVE!!!!
    But this is what you really want . . .
    “ . . . [VSC] lowers risk of fatal single vehicle crash by 56% . . .â€
    The Insurance Institute for Highway Safety.
    http://www.iihs.org/news_releases/2004/pr102804.htm
    http://www.hwysafety.org/srpdfs/sr4001.pdf
    P.S. Put your location in your profile. It will help with answers to questions. As a welcome gift, I shall now triple your PriusChat points to a grand total of twelve.
