Vehicle set up menu
Discussion in 'Gen 3 Prius Technical Discussion' started by BZzap!, Jan 7, 2013.
  1. BZzap!
    BZzap! Senior Member
    1,607
    878
    If I were to upgrade my HU to an after market GPS/audio system would the "Vehicle set up" menu be able to be changed/toggled off/on with the ScanGauge. I haven't seen any published codes for the Xgauge to change these settings. I'm assuming that being able to turn the backup beeper off and on, that the same would hold true for these other functions.
  2. pichner
    pichner Metallic Maniac #001
    66
    Minneapolis, MN
    I think the short answer is you will no longer be able to change those settings. Make sure you have them where you want them before you take out the head unit :)
  3. BZzap!
    1,607
    878
    I think so.
