Very bad hesitation
Discussion in 'Gen 2 Prius Main Forum' started by lottoman, Jun 10, 2007.
  1. lottoman
    lottoman New Member
    I got an 05 as a company car with no manual so I need your help again.
    My job has me visiting retailers on an assigned route, with the retailers--mostly convenience stores--located usually in strip malls.
    Some of these strip malls are below grade so when leaving the parking lot of the strip mall I have to accelerate slightly uphill upon leaving.
    Sometimes this can be a nightmare as the car seems to hesitate badly, sometimes not moving at all and then finally kicking in. This is not good and is very dangerous as I am mostly exiting into traffic moving anywhere from 45 to 65 mph.
    I have noticed an orange/yellow light go on on the display ( sort of on the right side of the display ) when this happens.
    Is this a common issue with this car or should I contact my fleet mgr. to arrange service for the hesitation? Is the orange light I see in this condition a check engine light?
    I thank you in advance.
  2. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Sounds like the VSC or the TRAC is kicking in because of wheel slippage...
  3. lottoman
    lottoman New Member
    <div class='quotetop'>QUOTE(SW03ES @ Jun 10 2007, 08:38 PM) [snapback]459340[/snapback]</div>
    I tried searching for the terms VSC and TRAC but the search function is not working well on this site but it could be my connection as we are having some stormy weather up here.
    Not having a manual puts me at a disadvantage so I do not know the acronyms stated above.
    I would think something kicking in would help me not hinder me and leave me in a dangerous situation, no?
    What do the acronyms mean and is this situation a maintenance issue?
  4. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    Also could be ignition coils. I had an '01 galant that did the exact same thing. I took it to a mechanic and he found out thats what was causing it. I replaced it and the hesitation never happened again. Ran the way it should have.
  5. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    No, it's the traction control system, and it's there to protect the HSD system from over-spinning MG1 (motor generator number one). There is probably oil on the road with water. This will allow the front wheels to spin up. Nothing you can do about it other than better tires for better traction. If you are still using the OEM Goodyear Integrity tires, get some better ones fitted. The difference will be like night and day.
    Oh, just thinking if your car is an early 2005, it may be improved with a software change. See your Toyota dealer about this. Tell them the traction control system seems too sensitive, and ask if there's a software fix. The details are on this forum but I don't remember the TSB number.
  6. SW03ES
    2,480
    176
    Gaithersburg, MD
    VSC and TRAC are the car's stability control and traction control systems respectively. Thats got to be whats happening. Are there metal grates in front of these entry/exitways?
  7. lottoman
    lottoman New Member
    <div class='quotetop'>QUOTE(SW03ES @ Jun 10 2007, 09:20 PM) [snapback]459370[/snapback]</div>
    Yes, there are metal drainage plates located at many of these locations which seperate the roadway and the parking lots from which I am exiting.
  8. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Lottoman,
    Yea avoid giving the car allot of throttle when your tires are on metal. Its kinda like that situation with the rookie race-car driver during the start of the Indy 500 a few years ago. Not being used to the tremendous torque of the Indy cars, he broke a half shaft right at the start of the race and caused a big mess. Mario Andretti was livid they let him in the race, let alone on the pole.
    It may only have 110 hp, but at slow speeds, the Prius out torques most other cars with 185/65-15 sized tires. If the tires start to slip, the traction control will kick in, and in the 2005's its reported very agressive, with a long delay before it returns throttle control to the driver.
    Supposedly the TC (Traction Control) and VSC (Vehicle Stability Control) have newer computer programs that can be loaded. The 2006 cars (with the newer programming) seem to be a little better in snow, but they still will really drop throttle on wet metal.
    Last time I had my tires rotated, the technician could not back the car over the ramp. So, they had me do it. In reverse the Prius is electric only. So, I brought the throttle up slowly to three-quarters, and then it backed up over the ramp. I quickly dropped throttle once it started to move. And it coasted out onto of the garage door. The tech was attending to something next to the car, and his eyes just went WIDE open when th car jumped backward over the ramp. After he had not been able to get it to move.
    In your situation, best to get some speed going, lift throttle and coast the front wheels over the metal grid, and then go 1/2 to 3/4's throttle up the ramp. As you know the Prius throttle has is very linear, and one can do very precise slow-speed control of the car with it, on dry pavement.
  9. SW03ES
    2,480
    176
    Gaithersburg, MD
    Thats the issue. You're applying havy throttle as the front wheels pass over the drainage grates which breaks the traction and engages the TRAC. Accelerate before or after the grates.
  10. lottoman
    lottoman New Member
    <div class='quotetop'>QUOTE(SW03ES @ Jun 10 2007, 09:52 PM) [snapback]459389[/snapback]</div>
    I thank you all for your help.
