Volt: 4 modes of operation...
Discussion in 'Chevrolet Volt' started by UsedToLoveCars, Oct 16, 2010.
  1. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    How the 2011 Chevrolet Volt Works
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Since Volt has a planetary gearset, just like PHV Prius, the mechanical loss due to it, would be the same.
  3. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    So does the prius. Normal-ev-Eco-power
  4. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Mode 3 explains why the MPG is so low in CS operation bolow 70 mph because the ICE is running is series hybrid mode which incurs electrical generator losses.
  5. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    I dont know why mode 1 is needed if mode2 exists. Volt only need mode2 and mode4.
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Thinking about this, I think they should have made two Volts. THe Volt E and the Volt SH. The Volt E would one direct gear from the motor to the axle differential gearset, and be limited to something like 85 mph, with poor efficiency above 70 mph. Or better yet, two motors coupled directly to the two half-shafts, and no differential!
    The Volt SH would be what they are going to be selling in a few months. The SH stands for Sports Hybrid...
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,532
    Southwest Colorado
    I would like to understand the 'direct' ICE to PSD linkage in mechanical detail. At the moment I gather the ICE has a shaft connected to the generator, and the motor has a shaft to the PSD. How is a mechanical connection made between the generator and the motor ?
  8. UsedToLoveCars
    448
    102
    I wonder if in mode 1, the unused MG is actually used for regen braking.
    I also wonder if mode 2 could be used below 70 for extra power, or if due to the speed of the ring gear that only about 70mph makes sense.
    I still want to know why a pure series hybrid design was rejected. Was such a configuration tested and deemed to be even less efficient than this Rube Goldberg design?
    Or did some UAW thug sitting in on the design meetings say "this thing has to have a transmission or else... Our gear cutters and transmission assemblers need to be in on this".
    I can just imagine this is how things work at GM.
  9. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    The generator is connected to the ring gear and the motor to the sun gear. The planet carrier turns the wheels.
  10. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    It is impossible since C2 is disengaged. For both MGs to regen, it has to be in mode2.
    It is possible. In CS mode, the generator+ICE can assist starting from 30 mph. Therefore, in mode2 the generator can assist as well.
  11. SageBrush
    11,627
    2,532
    Southwest Colorado
    I may just be really ignorant here, but I thought a generator takes mechanical input and puts out electric.
  12. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    It will do that in mode3 when clutch2 and clutch1 are disengaged.
    The answer depends on the state of the three clutches.
    If clutch2 is engaged, the generator will be connected to the ring gear of PSD.
    If clutch2 and clutch3 are engaged, both ICE and generator will be connected to PSD on the same shaft.
  13. austingreen
    austingreen Senior Member
    13,623
    4,165
    Austin, TX, USA
    The torque curve of the traction motor did not seem to meet GM's design requirements for high speed power. This necessitated mode 2 where the generator (MG1 in prius speak) assists the traction motor (MG2 in prius speak). A pure series hybrid was still possible, but would have hurt high speed performance, so they allowed your mode 4 to assist the motor (MG2) in hybrid mode. Then they claimed this software performance enhancement was really to increase efficiency.
    The big question is as long as they added this complexity for parallel/series operation why they didn't optimize it more. This would have provided better mileage. Of course the next logical step would to put in the turbo version of the engine from the Cruise and allow a button to provide hybrid acceleration even when the batteries have sufficient power. This likely would have improved mileage when driver dictated or more power and would not have required premium gas.
    There are 2 more modes from the gm design. Neutral with no clutches engaged, and neutral with generator with clutch 3 engaged between the motor and generator.
  14. austingreen
    13,623
    4,165
    Austin, TX, USA
    The generator is likely not strong enough to resist the traction motor so the psd is locked down making mode one. No need to power the generator (Mg1 in prius speak) while under 70mph in ev mode.
    Mode 3 may just be because GM did not design the thing for parallel operation so rpm's and gear ratios are likely not correct at normal speeds. I think it would require another planetary gear set, unless the volt already has gearing between the generator and engine.
  15. austingreen
    13,623
    4,165
    Austin, TX, USA
    probably just confusing terms. The engine is connected to the generator with a clutch. In series operation, mode 3, it generates electricity that can be fed to the traction motor and/or batteries. In mode two it acts like a motor and is disconnected from the engine but connected to the psd and draws power from the battery to help the traction motor in high speed operation. In mode 4 it acts like mg1 of the prius and I'm not sure if its a motor or a generator.
    If it was a normal series phev as gm originally described it, the generator would only be a generator as in mode 3, and mode 2 and 4 as well as clutches 2 and 3 would not exist.
  16. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Because at low speeds in CD, mode 1 will be more efficient.
    In CS, mode 3 is the 'serial' mode. Here this mode again is more efficient at low speeds. GM needs all the efficiency they can get with all of that extra weight and the crappy ICE they are using.
  17. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
  18. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
  19. austingreen
    13,623
    4,165
    Austin, TX, USA
    It really has 1 set of gear ratios, with mode 2 and 4 allowing the ring gear to move with the generator or the generator/motor combo. In fixed gearing (mode 1/2) there is approximately a 7:1 ratio between the traction motor and the wheels. Mode 1/2 transition should be very smooth as the generator and ring gear should engage at 0 rmp. mode 3/4 transition we don't know about as most of the reviews don't talk about it, but I would assume it is also smooth, and the motors can likely adjust speed to have very low rpm difference between the generator and ring gear.
    The blurbs on gm_volt seem to suggest the mode 3/4 transition can take place anywhere from 30-70 mph, taking place earlier at lower rpms when there is more load on the engine. The details of the software and power curve of the engine are not really clear.
