Volt's brake problem with the feel of sudden surge
Discussion in 'Chevrolet Volt' started by usbseawolf2000, Oct 12, 2011.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Volt owners are experience the sudden surge when the regen brake cut-off due to a bump on the road. I think the feel of the surge would last until the friction pad kicks in.
    The feel should be more pronounced due to the fact that Volt is heavier and regen brake is stronger (due to bigger motor). Sudden stop in braking would be feel like an unintended acceleration.
    Can Volt owners chime in with their experience?
    WHAM! "LOW TRACTION"
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Obviously sub standard. Let's have a full recall of all GM products and a witch hunt on their top management.
    Ooops, sorry GM's an American company with a big union that pays into and supports the present US Government, so nothing will happen then.
    3 people like this.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Well doesn't this sound familiar? Physics strikes again.
    There really isn't any way around this problem as long as braking systems are open loop, requiring the driver to modulate braking force to compensate for uneven braking. ABS helps retain control, but it does so by monitoring wheel rotation, not braking force. By the time the system notes lack of wheel rotation, the driver has already experienced the "surge".
    The way to fix this problem is to go to closed loop braking control, where an accelerometer monitors braking effort. The driver presses on the brake pedal, telling the computer how hard he wants to brake. The computer increases braking effort and monitors the accelerometer until actual braking effort matches that requested. Regeneration and friction braking are blended seamlessly to provide the proper force. If regeneration is reduced friction is increased to compensate.
    This sort of braking control can provide a uniform feel to the brakes over a variety of surfaces, up until the point when it is impossible to brake at the desired level. While it can control the braking effort, it can't create friction where it doesn't exist.
    Tom
  4. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Tom,
    Do you think it would require much more engineering and costs associated to make that change? I'd be surprised if the engineers weren't aware, but my guess is that economics takes over at some point?
  5. qbee42
    18,058
    3,076
    Northern Michigan
    The costs per vehicle aren't too bad, but when it comes to automobiles and other consumer products, costs are measured to the penny. Designers think long and hard about added even a few cents to the cost of a consumer product.
    The engineering is considerable, but similar to the other drive-by-wire systems found in the Prius. I think it will happen eventually.
    Tom
  6. gwmort
    gwmort Active Member
    985
    211
    Delaware
    I've got over 10,500 miles now and have never experienced anything like that.
  7. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    you, and the VAST majority of Prius owners. I say it's the unique part of driving any hybrid. Really, we can't seem to get past this? I'm all for a full GM investigation...since Toyota had to for a non-issue.
  8. wick1ert
    1,311
    183
    Delawhere
    Thanks.
    I would agree that it will happen eventually. Possibly as they get more and more hybrids on the road, the cost per vehicle may drop to a point they are willing to do it. I would be surprised if it isn't something already in the R&D area.
  9. austingreen
    austingreen Senior Member
    13,623
    4,165
    Austin, TX, USA
    That report was quite unlike the prius brake software problem.
    On the GM the complaint is when in L which introduces regen with foot off the accelerator, the braking skips when it loses traction. AFAIK there are not reports of brake problems when the driver actually puts their foot on the brake pedal. I would not put it past a software bug, as the prius problem was, but this is not a situation where new hardware is needed to close the loop. The driver is part of the loop and needs to hit the brakes when he wants to stop, just as he would using engine braking in a traditional car.
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    the volt is an expensive car... i would assume they would work to put in a lexus like equivalent of "even brake force distribution" and such.. since the lexus models really don't get the brake problems i've seen with the prius and now volt. i used to hot rod my parents rx400h... it acted like it was magnetically held to the ground.... sooo stable.
  11. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Even without accelerometer feedback (keeping the braking system "open loop"), I still don't see why Toyota or GM can not write the algorithm such that when the computer decides to reduce regen braking, it increases the friction braking accordingly to achieve a seamless transition.
  12. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    I drive over speed bumps, and rough roads everyday and have not personally had this happen.. Will try to see if I cannot get it to happen on the way home though.. So far everything seems smooth to me. Maybe an issue isolated on the 2011's? I know the 2012's have a software update that is supposed to be back fitted to the 2011's to correct some issues.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Try to write one, you will find it nearly impossible with the current hardware.
  14. austingreen
    13,623
    4,165
    Austin, TX, USA
    Yes it is quite straightforward. There are speed sensors at each wheel, the amount of regen energy can be monitored, and there is the speed sensor for the speedometer/odometer. Deceleration can be calculated from the current sensors. There is no need for new hardware, although accelerometers are now inexpensive. The toyota problem was a bug, that has been fixed. This has to do with regen in L, something meant to simulate engine braking not friction braking. I would not rule out a bug or lack of specification, but for all I know the software on the volt is operating the way the engineers intended it. This happens when the wheel sensors detect a slip and non-braking regen is removed from the comments. Without seeing the code, I would think a faster response to reengage brakes when an anti-lock event happens would be a possible solution.
  15. Roadburner440
    316
    59
    Hampton, VA
    I can't get it to happen on my car. I will try again in the morning. I was unaware there was even anything in the programming that affected regen braking as far as bumps and stuff are concerned. You would think that it would use the friction brakes to supplement the lost regen braking in a case like that since everything is done by wire. I have never had a problem with the braking feel on either car though.
  16. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The is deja vu, except affecting Volt folks. I wonder if they'll have the same pattern of many threads and arguments like we had over here...
    Bwilson4web used to collect pictures of spots where this phenomena can be repro on Priuses. Pics at http://priuschat.com/forums/gen-iii-2010-prius-main-forum/67528-braking-problem-18.html#post1049963.
    I've posted my known repro spot at http://priuschat.com/forums/gen-iii...99-poll-prius-brakes-problem.html#post1031776 but my Google Street View link there seems to have trouble. [ame="http://maps.google.com/maps?q=san+aleso+and+n+mathilda+ave,+sunnyvale,+ca&hl=en&ll=37.394119,-122.029264&spn=0.002474,0.001931&sll=37.393799,-122.029153&sspn=0.00007,0.004292&layer=c&cbp=13,236.12,,1,9.76&cbll=37.394282,-122.029212&hnear=N+Mathilda+Ave+%26+San+Aleso+Ave,+Sunnyvale,+Santa+Clara,+California+94085&t=h&z=19&vpsrc=0&panoid=-5crftgrV7BChonRx9VERA"]san aleso and n mathilda ave, sunnyvale, ca - Google Maps[/ame] should work.
    I was last in that area within the past month or so and the pavement is still cruddy, like that.
  17. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Braking while running over a storm grate will cause it.
  18. qbee42
    18,058
    3,076
    Northern Michigan
    That is how it is presently done. The problem only occurs when traction is suddenly lost, not when the computer gently transitions from regeneration to friction braking.
    Without an accelerometer to detect braking, the only way the computer knows when traction is lost is when one wheel stops turning as fast as the others. This, by necessity, involves some rotation of the other wheels, which means it takes time. The loss of braking effort during that time produces the "surge", or jerk.
    Note that this is not unique to regenerative braking, but also happens with normal ABS brakes. This same issue has been reported with the Toyota FJ Cruiser, which is most definitely not a hybrid, but does use electrically assisted brakes.
    Tom
  19. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    I didn't with the "we're all going to die" braking in Prius either. It took quite a few tries to finally get it to trigger.
    My commute takes me over train tracks. Despite smacking into them every day, nothing. Then I hit the brakes really hard just a moment before contact, it happened!
    The reality of how much of an impact was required really stirred frustration with the magnitude of the smear campaign which resulted from it. Sure, a software update is good to encourage. But clearly, the issue didn't warrant the magnitude of the response & attention it got.
    Now Volt has to deal with it. Think about how many don't want plug-in vehicles to gain any traction, who'd like to put a brake on them, perhaps a sudden surge of negative attention. (puns intended)
  20. qbee42
    18,058
    3,076
    Northern Michigan
    It does, but it takes a finite amount of time to detect the loss of regenerative braking and switch to friction brakes. The previous posts discuss the details.
    Tom
