Want to add a method to lock doors from rear of car, when in ready mode.
Discussion in 'Gen 2 Prius Main Forum' started by RichEO, Sep 14, 2024.
  1. RichEO
    RichEO New Member
    Manchester
    Active
    Hello.
    I have a gen2 without smart key.
    I would like to lock the doors when in the back (whilst in ready mode) without having to lean through to the front.
    I was going to connect an extra switch to the wiring but it is not obvious which wires and the switch is some unusual (to me) sliding mechanism. After testing the contacts it does not seem to be a straight forward switch.
    Does anyone know which wires could be connected to activate lock/unlock?
    I bought and programmed a 2nd key but it does not operate the doors when a key is in the ignition.
    Other options I am considering are a finger bot, servo, or long stick with push/pull to lock/unlock.
    Thanks.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,109
    622
    Southern California
    Wiring info 2007 | PriusChat
    has a list of wires/pins in text form in the 4th post. There is a note on the unlock wire that it is a double pulse. That suggests that the lock wire might also be pulsed, as opposed to the more typical "pulled to ground when engaged", as for instance, on the door open sensors. Anyway, I would start by putting a voltmeter on that wire and see what happens when the power lock "lock" position is pressed. If it is a pulse it might be too fast for a digital multimeter to see, but if you happen to have an old analog voltmeter the needle should at least twitch when the pulse goes by.
    RichEO likes this.
  3. RichEO
    RichEO New Member
    Manchester
    Active
    Thank you
  4. MAX2
    MAX2 Senior Member
    1,343
    421
    101
    Third planet from the Sun
    When the car is running and the key is inserted into the ignition slot, the door closes easily with a mechanical key.
    All doors are locked immediately by turning the mechanical key.
  5. pasadena_commut
    2,109
    622
    Southern California
    I know the car has a "lock automatically after TIME if the key is out of the ignition and the doors are closed" mode. I made sure it was disabled on our car. Anybody know if a Prius has a "lock automatically after TIME if the key is in the ignition" mode? That would serve the same purpose. However, I would only turn that on if I always had a physical key on me. Otherwise it is pretty much guaranteed to lock you out of the car at some point.
