Wanted to gauge what the issue(s) might be with my engine
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by darkside_619, Feb 14, 2024.
Tags:
  1. darkside_619
    darkside_619 New Member
    San Diego
    Hello all.
    I have a 2014 Prius V3 that has over 331k miles on it. Last year I had to replace the catalytic converter with a brand new one because the previous one had reached end of life.
    However, for the last few months I've been getting cylinder misfires. Also, before that if I put new engine oil in it would be empty within a week so I'd have to keep putting new engine oil in since my prius was burning it off quickly. I know there wasn't a leak issue since I checked that (no oil puddles under the car when I park it, etc.).
    A few days ago my car turned off while I was driving it and I took it into a shop for a diagnosis (had to get it towed since when you turn it on it makes loud noises and I didn't feel it was safe to drive).
    Before I took it into a shop I used a reader to get the engine codes and this is what I found (8 in total)
    1) P0300
    2) P0302
    3) P0303
    4) P0304
    5) P0171
    6) P0101
    7) P0420
    8) P3191
    Obviously, there's a lot wrong with this engine. The mechanic hasn't gotten back to me yet with a diagnosis but I'll probably take it to a different mechanic anyways since he's taking too long. I was curious however what you guys think the issue(s) might be and how much I should expect to pay to fix all of them and if it's even worth it to fix all of those issues in terms of cost.
  2. darkside_619
    San Diego
    For a quick update, the mechanic just got back to me and said that the intake manifold is damaged and he recommends replacing it before checking to see if there are other issues.
  3. Mendel Leisk
    40,236
    How recently did you get it, and at what miles?
    I'd suspect head gasket failure, judging miles, 3rd gen reputation (including the v's) and the codes you've got.
    For the oil loss, check if you've got the "low-tension" piston rings, compare your VIN to the attached. For that, you can either replace pistons/rings, or new short block.
  4. darkside_619
    San Diego
    Thanks for the help. I appreciate it. This prius used to be a taxi which is why it's logged so many miles. I got it at 248k miles four years ago and now it's at 331k miles. I will look into the piston rings for the oil loss issue.
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,292
    5,664
    Texas Hill Country
    Almost certain to have a head gasket leak and excessive oil burning which led to the cat failure.
    If you want to keep it and the rest of the car is excellent, get a rebuilt engine.
    Air_Boss likes this.
  6. vvillovv
    vvillovv Senior Member
    4,315
    1,494
    NY
    At 330K miles, replaced the cat last year, was a taxi before you got it, 8 trouble codes, V shutdown and wouldn't run currently, burns oil more than typical ( how often do you add oil and how much oil a week? )
    Anything else you noticed ?
    From a repair / diagnosis cost basis, and the fact your mechanic is recommending an intake manifold to start you off, you might want to check how much for a engine swap, before you go for the manifold while keeping your fingers crossed the cars not gonna need another repair after that.
    Or contact Hybrid Pit Stop or Gasket Masters and ask them how much for an engine install, if they are close enough to you.
    Gasket Masters ( main location in the bay area ) does a lot of work on taxi s so might be able to give you a better idea of what is wrong, listing the things you've already posted.
    #6 vvillovv, Feb 16, 2024
  7. ChapmanF
    16,951
    Your codes are: (1–4) a lot of misfiring; (5) the mixture too lean, a perfectly cromulent reason for a lot of misfiring; (6) the ECM not trusting the airflow reading, hand-in-hand with the mixture too lean; (7) the cat issue you already knew about, and (8) the engine producing piddly power, no surprise with the too-lean mixture and all that misfiring.
    A hole in the intake manifold lets air in downstream of the flow sensor, which makes the mixture too lean and the flow reading not trustworthy, so yeah, that can be the whole story except for the oil consumption and the cat. Fix the hole before jumping to any other conclusions about the engine.
    The oil consumption is still going to be a nuisance, though, and no good for a replacement cat.
    Brian1954 likes this.
  8. Mendel Leisk
    40,236
    It’d be interesting to know in more detail the nature of the intake manifold hole. It might be an extensive crack, but if small maybe 2 part epoxy would fix.
    Tim Jones likes this.
  9. Tim Jones
    Tim Jones Senior Member
    1,738
    562
    SE Texas
    2011 Nissan LEAF
    Get a new engine.
    vvillovv likes this.
  10. vvillovv
    4,315
    1,494
    NY
    If an engine swap is worth the cost calculation of a Prius with 330K miles.
    Or go with the mechanics recommendation, while knowing you're rolling the dice with repair costs, either way.
  11. Tim Jones
    1,738
    562
    SE Texas
    2011 Nissan LEAF
    I also agree with this.... but out of oil weekly sounds pretty bad.
    But coming up....
    Brake Master
    Traction battery.... water pump unless it's been changed..... and what about the AC....
  12. vvillovv
    4,315
    1,494
    NY
    I had to go back to the OP and make sure the out of oil in a week was the actual wording in the post, because I missed that exact wording in with all the other issues listed.
    Seeing that is exactly what is posted in the OP, I'm not sure I'd even go for the new engine on a cost to possible future repair(s). But that's just me and I've got my own money pit sittin on a 12 volt tender waiting for a deal.
  13. rjparker
    9,292
    5,664
    Texas Hill Country
    When Toyota did free rebuilds to replace the pistons and rings on these cars it was because of excessive oil consumption like the op’s car. The kind where you often run out of four quarts and get that pesky oil pressure light. A rebuilt engine is the only way to save a 300,000 plus car with terminal oil consumption. Especially after replacing the clogged cat. Who cares about the fuel trim or egr cleaning at that point.
    Tim Jones and vvillovv like this.
  14. ChapmanF
    16,951
    Well, if the rebuilt engine doesn't come with an intake manifold and this leaky one is reused, the fuel trim is gonna stop that engine from running too.
