Warning light mystery???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dr. Katherine Nell McNeil, Nov 22, 2015.
  1. Dr. Katherine Nell McNeil
    Alpine, CA
    For the past 3 days my warning light has come on. Just the exclamation mark....nothing else lights up...it flashed quickly then goes off. It seems to do this when I go around a corner. I thought nothing of it the first time it did this. However, today is the 3rd time it flashed. So anyone have any ideas....possible tire pressure? I have not gone out and checked that but I will. It is just strange that no other light comes on.
  2. fuzzy1
    10,332
    Have you checked engine oil level recently? If not, do it right now. Sloshing low oil level is known to trigger a momentary warning, but only when the oil is already dangerously low.
  3. Dr. Katherine Nell McNeil
    Alpine, CA
    I shall go and check right now.
  4. Air_Boss
    Air_Boss Senior Member
    4,124
    1,146
    New Yawk
    Low brake fluid level, same indication.
  5. Dr. Katherine Nell McNeil
    Alpine, CA
    Bingo....I am humbled by your knowledge....and by the fact that it saved my butt. Uh, I just put about 4 quartz back in. I hope it is not to much. I kept checking and after I put more in it seems like it is way above the high level.
  6. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    Too much oil is not good either.
  7. Dr. Katherine Nell McNeil
    Alpine, CA
    I guess I will check that also but the oil was dangerously low.
    I know.....what is the worse that can happen? This has never happened to me before....so I can't take it back out.
    #7 Dr. Katherine Nell McNeil, Nov 22, 2015
  8. Mendel Leisk
    40,236
    The dipstick can be really hard to read: oil smears along the edges, it's hard to tell where it actually stops.
    Do multiple checks, flip it over, sometimes one side is more distinct than the other. View it in good light, if you're longsighted use your reading glasses.
    If it does turn out to be overfilled, anything up to 1/2" you can live with. But more than that it'd be good to drain some off. Dealership could do that for maybe 1/2 the cost of an oil change. Or just cave and get an early change.
  9. xliderider
    8,016
    3,198
    Honolulu, HI
    Overfilled oil can get in the egr system and get into the throttle body.
    You can let some oil out by loosening the oil pan drain bolt. But make sure it's really overfilled.
  10. Mendel Leisk
    40,236
    I find the face of the dipstick towards the front of vehicle is slightly easier to read. Also, try pushing it in just to the plastic handle start, to see the shift: that'll help to show what it is you're looking for.
    If you decide to drain a bit of oil yourself, get a graduate (anything will do, even a pickle jar with rough measurements), loosen the drain bolt, JUST to the point of it almost coming off. Then tilt it slightly, and keep pressure on it, get a thin stream going. Don't even think about removing it completely for a second or two, lol.
  11. fuzzy1
    10,332
    It just means you haven't been spending excessive amounts of time on PriusChat, as some others do. You are not the first or second person to ask about this in the past few months.
  12. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    The suggestion of getting an oil change is a good one. Then you can start off with the right amount (check!) and keep track of where it goes from there.
  13. Dr. Katherine Nell McNeil
    Alpine, CA
    I have done multiple checks and I still can't tell. Do I need to start the car up and let it run and check it after? On one dip it looks like it is a little over the high mark then on the next it is just smeared.
    That is probably my best bet....but that will have to wait until I get paid on the first.
    #13 Dr. Katherine Nell McNeil, Nov 22, 2015
  14. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    It probably is important to get the car running to have things even out but then shut it off and wait a few minutes for the oil to settle back into the pan.
    Make sure you are parked on a level surface.
    And wait at least a few minutes between pulling the dipstick or the oil gets pulled up onto the tube walls and you won't get a clean measurement.
  15. Dr. Katherine Nell McNeil
    Alpine, CA
    I will do that first thing tomorrow morning. Writing myself a note after posting this. Thanks everyone for your help.....I know that your help saved my car.
  16. xliderider
    8,016
    3,198
    Honolulu, HI
    I've had my oil changes done at the dealer, and it's been overfilled many times. So many times, that I've installed a Fumoto valve in place of the drain bolt so I can easily drain off oil to proper level.
  17. Mendel Leisk
    40,236
    I think you should persevere, practice reading the dipstick. It's no small feat, and doesn't get any easier. Again: the level is slightly clearer on the front face. For practice, try not pushing the dipstick completely in, stop at the plastic handle. This'll shift the level down, and that in turn makes it clearer what you're looking for. It's a zone where the oil starts covering the complete width of the blade. And it's subtle as heck on the Prius, never had this issue with our Hondas. Never got this mpg either, tho.
  18. bisco
    50,809
    how many miles on her, and at what mileage was your last oil change. something is not right.
  19. Former Member 68813
    3,524
    983
    US
  20. Former Member 68813
    3,524
    983
    US
