Weird noise above 40km/h from electric motor not usual
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Trospe, Aug 14, 2022.
  1. Trospe
    Trospe New Member
    Greece
    Hello guys I am an owner of a 2008 Toyota Prius with 160k kilometers on the dash. My car is making a really weird noise above 35-40km/h and it just gets louder when accelarating. The noise is like the noise the electric motor has but much louder and deeper. It does it when accelarating or even if you let off the gas until it reaches below the above speeds. I have had the dealer here in Greece diagnose it but they say they can't hear anything wrong. They checked wheel bearings, water pump, inverter pump and everything that could be associated with the sound but they found nothing wrong. If anyone has an idea just say it because I am frustrated with this sound (and because it sounds expensive). For any more info ask me below so that I can help you. Sorry if my english are bad :)
    50,805
    welcome!
    can you make a recording? you'll need 5 posts to make a link
    Trospe likes this.
  3. Trospe
    Trospe New Member
    Greece
    Of course I will make a recording when I return back from my holidays!! Thank you very much I wish that we can sort this out.
  4. Fred_H
    Fred_H Misoversimplifier
    558
    481
    28
    Germany
    It could also be unevenly worn tires, or a bad CV joint, or bad or insufficient transmission fluid, or a bad gear or bearing in the transmission.
    You could try swapping tires, inspecting the CV joint, changing and inspecting the transmission fluid, and looking for leaks.
  5. Trospe
    Trospe New Member
    Greece
    Hey thanks for the answer! As soon as I return I will do a full service on the car anyway so I will of course look at all the things you mentioned. I am sure that they are not any leaks from the trans or the engine (so I don't think that the trans fluid is low) but I will check again just to be sure. But the CV joint might be the answer because I was also thinking of that. The tires are due to a change in a couple thousand kms but the tread is even on all corners. So to be clear I will change and inspect trans fluid, inspect CV joints and check the tires again.
    Are Toyota Prius of our gen known to get bad CV joints or problems to the trans in the mileage my car has? (160k kilometers or 99.500 miles). Thank you!!
  6. Trospe
    Trospe New Member
    Greece
    Alright guys I have taken the car to 2 dealships here in Greece no one can figure out what the issue is with the car. I also did a trip which was about 1400kms without ANY problems at all and without the noise getting worse or something. The car operates just fine but I can't live with that noise. I tried to shoot a video so you can hear it but it's difficult to hear it through my phone. I will try with another one. My last hope are the tires and I will change them putting some Turanza T0005. Everything you can suggest might help. Dealers here in Greece have no idea about our cars even though there are a lot of Prius especially 2nd gen.
  7. ChapmanF
    16,949
    Is it a noise like a hum, something with a musical pitch? Have you noticed whether it has a fixed relation to the road speed of the car?
    If you drive the car at 30 and then at 40, does the pitch go up by a perfect fourth? And if you drive at 30 and then at 45, does the pitch go up by a perfect fifth? And stay the same, as long as the car has the same road speed?
    If so, it is something in a fixed relation to the wheel speed.
    In the US, a common example of a perfect fourth is the opening notes of "here comes the bride" (a/k/a Lohengrin wedding chorus), and of a perfect fifth, the first interval in "twinkle, twinkle little star". I don't know what usual Greek examples would be.
  8. Trospe
    Trospe New Member
    Greece
    Look, I am not a musician and I can't understand if you are talking serious or not :'). The sound starts at about 30-35km/h and around 45-50km/h it gets full volume. I drove the car at speeds around 150-160km/h and the noise didn't change volume or pitch at all. Happy to answer all the questions I get so that I can get my Prius fixed!
  9. ChapmanF
    16,949
    Here in the US, I normally suppose that even a non-musician will be able to say if something sounds like the opening of "here comes the bride" or "twinkle twinkle little star". Those are just sort of universally known. There may be such songs in Greece but I don't know what they are.
    However, if your noise has a pitch and the pitch didn't change at all when you changed road speed, that would indicate some source other than the tires, wheels, wheel bearings, etc. All of those sources would make a pitch that changes with road speed (and changes the exact way I mentioned in #7).
    There are other possibilities where a pitch would vary with the engine RPM, or with the MG1 RPM.
    It is a bit difficult to think of possibilities that would lead to a noise whose pitch does not change at all.
  10. pasadena_commut
    pasadena_commut Senior Member
    2,109
    622
    Southern California
  11. Trospe
    Trospe New Member
    Greece
    Alright guys I am back after a long time but i found what the issue was. Well I had an inner front right bad CV boot which caused the CV joint to loose lubrication and contain road dirt and thats why the noise I was talking about was made. I bought a full set of CV boots directly from Toyota for about 90 euros for each side which had lube, clamps and both CV boots for each side. The originals lasted for 15 years so I said why I dont buy the originals again so they last as long and not worry about anything.
    Fred_H likes this.
  12. Trospe
    Trospe New Member
    Greece
    Finally solved the problem guys. I found out that the noise was a bad front left wheel bearing. Quote from the dealer almost 700 euros, 660 to be exact, because they say that the bearing might be stuck in the hub and they will have to change the hub, the wheel bearing and the brake dust shield. If the bearing isn't stuck in the hub I think it will be at around 200 euros. You can now have a taste about Greek Toyota Dealers as well (they needed almost a year to find where the noise was coming from and then they quote a huge amount of money). :)
  13. bisco
    50,805
    sounds like here :p
