Well, i simply do not know
Discussion in 'Gen 3 Prius Fuel Economy' started by DaveinOlyWA, Jun 13, 2009.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ok. i installed my door sills and had to disconnect 12 volt battery to do so which reset everything in the car including (actually saved addresses and phone settings were ok) my trip meter.
    now before i was at 64 mpg. after install, everything was reset except odometer. well drove around a little, did about 15 miles at 58 mpg then refilled.
    according to estimated gas use which should have been just over 7 gallons, well i put in 8.335 gallons which puts me at just under 54 mpg. that is nearly a 10 mpg difference.
    what happened??
    this is only the 3rd time putting gas in and the previous two times were within 2 mpg high once, low once.
    got gas at Costco, so sent them an email with my concerns. will post their response, but not sure its them. any thoughts on this? is it possible the odometer is messed up? seems unlikely
    **edit**
    ok, its been a while, but have finished the next tank and its low as well...622.9 miles MFD says 68.1 which should mean it would take 9.15 gals... well it took 9.983 which computes to 62.4 mpg. with 70,000 miles of Pri driving, i have never had any single tank as far off as this one and this one is still MUCH better than the previous one.
    i ran this tank in eco mode the entire time (after playing with it this afternoon, i figured that after about 3 inches of pedal travel, its actually in power mode anyway. its almost like the old 4 barrel carb days when it switches over)
    but wondering if maybe i try running it in normal mode to see if that makes a difference
  2. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    That is odd indeed. :confused:
    I guess just drive it and fill it up again and track the progress?
    We should have others do the same and see if yours is an isolated incident.
  3. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Man those must be some heavy door sills.:eek: Either that or they have totally messed up the aerodynamic flow.:D
  4. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Maybe not directly but he is probably driving around with his doors open to show them off to other drivers and he is ruining his aerodynamics AND draining the batery with those glowly things!
  5. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    hmm, well not quiet that bad, but IF...IF say i was to have shown off the sills SEVERAL times which would mean the doors were open an inordinately longer time than normal which would have run down the 12 volt battery which means on startup the engine would have to run longer to run the motor to charge the...
    hmmm and to think it all started with a fly
    anyway, i am thinking the pump ripped me off or i was siphoned. i do live directly across the street from a park where tons of kids hang out. now, i have not noticed any damage to my car or anything that would indicate a break-in.
    other than waiting to see if Costco finds anything wrong with the pump, the only thing i can do is just wait a few weeks until i can get a decent fillup and try it again...
  6. bwilson4web
    15,929
    <SIGH>I can't count how many times I've had to say the same thing. It is the tell of a Prius owner.
  7. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    It's ok Dave. We won't think less of you for showing off your new mod and ruining your gas mileage but do you really think it is fair to blame Costco? :p
    With my tiny bladder I have to refill once a week. :( So I never have to wait very long to be disappointed in a tank. lol
  8. Randall Rash
    Randall Rash Member
    149
    25
    Rockwall, TX
    Or if you drive with your doors open so you can see your door sills, that would be a mileage killer.
    (OOps, already stated in the very next post. Ha.)
  9. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    rofl.....
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well. only 50 miles on new tank... now IT SAYS 62.2 mpg... i guess we shall see.
  11. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Aye, not much else to do. I'll be looking forward to your next fill up. :)
  12. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    I'm pretty sure it is defective, but I'll need to drive it for a few months to diagnose the specific problem for you... :eyebrows: No fee for the troubleshooting though! ;)
  13. raidbuck
    raidbuck New Member
    133
    Baltimore ,MD
    Hmm, right now I fill up every other day, with a 2001 Echo (about 32 mpg). Guess I'll get lots of chances to measure fuel economy when my waiting finally ends.
    Rich N.
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well currently we basically have an extra vehicle so the 2010 does not get driven daily. i still use the Zenn to commute to work and for short errands simply because even great mileage on the 2010 cant compete cost-wise with the Zenn.
  15. billklug
    billklug Junior Member
    23
    If it's any comfort, I just checked HUD against caluculated (miles over fuel) and found a difference as well. HUD indicated 52.8 but calculated (and yes I filled to the same level) was only 50.3. While it's not 10 MPG, it is different. I suppose it's like this: A man with one watch always knows what time it is; a man with two watches is never sure. Regardless, and either way, it's a whole bunch better than my Gen 1 ever did, so no complaints here.
  16. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    As with the GII model, the GIII can't be relied on to indicate -true- mileage in only one fill. My GII MFD is -usually- quite close (+or- 0.2 l/100km), but sometimes....????!
    So relax, enjoy the ride. Calculate later. ;)
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well this is my 3rd fill. including a "half fill" but that was the dealer tank. filled that with 6 bars left because i was headed out on a long trip and plus, wanted to move out the dealer mileage. i was out of town when my car was delivered and i told them when they called i was unsure of my plans (up until they had called, i had not even looked at the financing options) which, i think, gave them the impression that i was not going to buy it. well when i did finally pick it up 4 days later, it had 25 miles on it at 35 mpg. well, i brought it up eventually, but the point is, the first mini-fill and the 2nd fill were within "normal" ranges. less than 3 mpg difference. one higher, the 2nd lower...
    just going to see how the next tank works out. Costco responded to me that they forwarded my concerns to the station involved. i dont expect to hear much from them anytime soon... so we shall see. sitting at 300 miles on this tank, so still a ways to go.
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    new tank info, OP edited
  19. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Dave, I've found the trip computer to be 2-3mpg higher than actual as well.
  20. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    2-3 mpg i could accept but 5.7 mpg on this tank, 9.7 mpg on the last one. what gives?
