What are symptoms of a failing steering rack motor?
Discussion in 'Gen 3 Prius Technical Discussion' started by ES44AC, May 16, 2021.
  1. ES44AC
    ES44AC C.A.U.S
    319
    77
    After many searches and posts I see some have the same/similar problem that I do. IE: When driving on a straight section of road I am constantly making tiny corrections to stay in my lane. but worse yet, when I am in a long sweeping curve, I can let go of the wheel and it stays where I have it. It doesn't want to center itself.Now if I do this in a parking lot and really make a tight turn, the wheel will come back toward center, or at least make an attempt to.
    It wasn't always like that but it sure is irritating.The feel at the steering wheel is 'notchy' or 'sticky' feeling when I try and move it. I have to constantly be steering and if I look away it will drift out of my lane, really annoying,
    .Back in the day if someone brought me an MG with a similar complaint I'd suggest that the rack was bent. Of course there was no power assist of any kind.
    The vehicle is a 2011 Prius II with 71K and stock rims and good tires.Makes me wonder if it's the rack motor failing or a tight strut bearing maybe not the motor. <shrugh> Alignment is good too fiw. NO I didn't hit anything to bend the rack if in fact that's what it turns out to be,
    Thanks to all who reply,
    ES
  2. mr_guy_mann
    mr_guy_mann Senior Member
    3,925
    1,888
    NJ-USA
    I would suggest having the car put up on a lift (or safely jacked & on safety stands) in order to completely inspect the steering and suspension. There could be a problem with the steering assist, or there could be a binding U-joint in the steering shaft, or a tight tie rod end, ball joint, or strut / mount.
    I am not familiar with the Gen3 personally, but I would expect most faults with the steering assist to set fault codes and turn on a warning light.
  3. ES44AC
    ES44AC C.A.U.S
    319
    77
    Thanks, I know I need to be under the car. I talked to the dealer and he said he'd go with me to test it or better yet let him drive it..Clearly there's something amiss.
    Regards 'ES"
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I would tend to agree with Mr guy mann. Alignment and/or suspension issues can be the cause.
  5. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    I had a 2010 Prius that did that. I found out after I bought it that it had been wrecked before. Had an alignment done and it didn't help. No-one could ever find the problem so I finally traded it.
