What does the Wheel Weigh??
Discussion in 'Gen 2 Prius Main Forum' started by yes.ittransforms, Sep 1, 2008.
  1. yes.ittransforms
    yes.ittransforms 100K!!!!
    62
    Las Vegas NV
    Hey ALL,
    I was wondering if anyone can tell me how much just the rim on a NON-touring 2007 Prius weigh so I can get some black lighter rims when my tires need changing. :confused:
    Thanks,
    Jonathan
    P.S. -- if anyone knows some good roms that are black any input would be nice!!
  2. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I've read elsewhere on this board that the 15" Prius wheel weighs 14 pounds.
  3. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    The 14" Classic (aluminum rim and tire) weighed 24 pounds.
    The full-size spare I built for that Prius using a steel rim weighed 32 pounds.
  4. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    When I installed my mud guards at less than 300 miles on the odometer, I weighed the wheel and tire combination and got 32 pounds. According to the spec from tirerack.com a Goodyear Integrity weighs 17 pounds. So I'd concur with what appeared elsewhere (14 pounds) as that leaves 15 pounds for the wheel+pressure sensor+trim ring.
  5. yes.ittransforms
    62
    Las Vegas NV
    Hey All
    Thanks for all of your input I LOVE this site!!
    Jonathan
  6. NovaBimmer
    NovaBimmer New Member
    17
    NoVA
    here's the wheels You need to save weight
    that's in kilograms, too, so they're a hair over 6 pounds... it's black carbon fiber, so don't know if that'll work for You or not
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Oh wow! I can see it has 5 lugs. Is that 5x100? How many inches is the diameter?
  8. NovaBimmer
    17
    NoVA
    it's an 18" as far as I know.
    also awesome lightweight wheels are O.Z. super- or ultraleggeras
  9. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    You can also use the Volk Racing wheels previously posted about. They were developed -FOR- the Prius as mileage improving wheels.
    weight comparison
    ce28 ecodrives
    15 inch: 10.1 lbs
    16 inch: 10.8 lbs
    Prius factory wheels
    15 inch 14.3 lbs
    16 inch 15.2 lbs
  10. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Scientific Question
    Scientific Question
    Does the wheel weigh more while in motion and spinning, than at rest?
    Since the outer part spins faster, would an aluminum alloy wheel 15" rim make a huge difference, versus the stock rim?
    I don't know the answers.... It should weigh more in motion, but that would that not be a tiny % increase?
  11. David Beale
    5,963
    1,985
    Edmonton Alberta
    No, the weight is constant. The rotational momentum or kinetic energy rises from 0 (at rest) to some value which increases with speed.
    The stock rim -is- an aluminum alloy wheel. A lighter wheel will make a difference, if that is what you are asking. It takes energy to accelerate a wheel up to a given speed, and usually you can't recover all of that energy. A heavier or higher mass wheel takes more energy to accelerate. You can't get it all back because in the real world if you have to stop, you have to do so in some finite distance (before you hit the vehicles in front of you, for example). Therefore you must dump some of the energy in the rotating wheel. Even the Prius, with regeneration, can't recover all the energy. With regeneration, it's claimed about 50% can be reused, overall, with generation losses, battery charging losses, battery draining losses, and finally, motor losses. You also loose ALL the energy from about 7 MPH to 0, as friction braking takes over.
    I'm waiting for someone who has purchased the Volk wheels to post whether they can notice the increase in fuel economy. There should be -some- improvement, it's just a question of how much. The carbon fibre wheels posted above -could- give even more improvement, but being 18", the tire may waste it in extra friction to the road. It -would- handle much better however, due to the tire contact patch being much larger.
    Finally, there is one thing the OP hasn't talked about yet. Whether you can use the stock TPMS sensors in whatever aftermarket wheels he chooses. They -may- fit in the Volk wheels.
  12. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    rluciano owns a set and he confirmed (in a PM) that OEM TPMS fits in the Volks Eco Drive. His post with picture of his Prius is here.
  13. David Beale
    5,963
    1,985
    Edmonton Alberta
    Thanks USB. It's hard to keep up with all the posts. This forum is HUGE.
    Thanks to Danny!
    So the only thing keeping me from getting the Volks is the tuner nuts you need to use (they are junk!). Oh, and the $2200 and worry whether they will arrive. ;)
  14. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    i wonder if my accord hybrid rims fit on the prius, their 16 inch 5x100
  15. tecrench
    tecrench Junior Member
    64
    MS
    What wheels are these and $$$, TIA
  16. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    So you're saving just 4.2 lbs per wheel, or 16.8 lbs per car set. That is the equivalent to the weight of just over 2 gallons of gas; so you should get the same effect on MPG by not filling your Prius gas tank by more than say 9 gallons of gas, so that you are not accelerating a mass of gasoline equivalent to the wheel set weight at any given time.
    OTOH you would presumably get a smoother ride due to the reduction in un-sprung wheel weight.
    Just a thought from a different perspective.
  17. richard schumacher
    7,664
    1,042
    United States
    Certainly it weighs more when moving: m = E/c^2. But you'll never notice it.
  18. David Beale
    5,963
    1,985
    Edmonton Alberta
    Not quite. Because of the rotational momentum you loose more energy accelerating and decelerating the wheels than you do if you were just carrying the extra weight in the car (as fuel, per your example). So it's more than just the extra weight.
    And yes, the car -may- handle better due to the lower unsprung weight, IF the suspension is still adjusted properly (as in tuned for optimum dampening).
    The combination effect of the extra weight you -could- drop with lighter wheels is:
    1. Less overall weight of the car.
    2. Less rotational momentum you have to increase and decrease.
    3. Less load on the brakes, so they heat up less (in racing applications, not with the Prius, the difference in the Prius wouldn't be large enough to worry about).
    4. Less unsprung weight, so you can make the car handle a lot better.
    All the above combine to make it very tempting for racing, to spend "uber dollars" decreasing the wheel weight. Which is one reason "Volk Racing" is a company known for their light weight wheels. Off road racing is different, as there wheel/tire strength is king.
  19. ronhowell
    681
    32
    Cypress, CA.
    No, Richard. The equation is M = Mo/(1 - v^2/c^2)^1/2 where Mo is the mass at rest , v = the object velocity and c = the speed of light. But you are right, the last term is as close to zero under normal circumstances as makes no difference. Everything is relative, is it not?!
  20. Flying White Dutchman
    4,374
    313
    wo those carbon wheels are light!
    whats the price?
