What exactly is supposed to go in the under deck tray in a 23/24 Prius Prime?
Discussion in 'Gen 5 Prius Main Forum' started by mowgli, Oct 12, 2024.
  1. mowgli
    mowgli New Member
    Massachusetts
    2024 Prius Prime
    XSE Premium
    These cutouts sure look very specifically shaped, but it doesn't seem like Toyota wants to tell us what for
    To steal an image from Reddit and annotate it:
    A is for a towing eyelet
    B is for the emergency tire puncture repair bottle
    C is for a (Toyota-sold) tool bag containing a jack handle and wheel nut wrench
    D is for a jack
    E is for triangle warning reflectors
    F is for the emergency tire puncture repair compressor
    G is for the charger
    H is for a Japan-only accessory that will allow you to route a power cord from outside, through a window, and to the power outlet in the back without having to leave the window open ("Stopper, rear door glass" part #67217-47020 if anyone is curious)
    But I can't find any info on the five spots marked ?
    I'm thinking the three perfectly smooth perfectly square spots in the top might not be intended to store anything, but the other two on the left side seem designed to hold something specific, any ideas?
    AndersOne likes this.
  2. Hammersmith
    Hammersmith Senior Member
    1,888
    1,879
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The uppermost right and left corner squares are where the deck board slots into. Not sure about the middle square. The other two spots on the upper left are for the socket if you have wheel locks and the longer slot is for a centering stud if the car had come with lug bolts instead of wheel studs like was originally planned.
    If you go to bolts(like most European cars), it's hard to hold the wheel in place while starting the first bolt. So they give you a hard plastic aligning stud. You push or thread the stud into the hub and that gives you something to hang the wheel on while you get the first bolt in. Once four of the bolts are started, you pull out the alignment stud and replace it with the final bolt. Between the preproduction cars and the regular production ones, Toyota decided to switch from bolts to studs(because of the bolt problems on the bZ4X) and then the car no longer needed the alignment stud. But the design of the foam deck boxes was already set, and it wasn't worth it to modify them to remove the slot.
    RandyPete likes this.
