What happened to my Prius??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusTick, Feb 26, 2011.
  1. PriusTick
    PriusTick New Member
    Hi All,
    I have run my 2007 Prius car for 3 years without a -single- issue. I drive it every day and I am pretty good with maintenance.
    Last night I went to start the car and the LCD display started to act funky and no start. Tried, tried, just dead. The interior lights were weak.
    Today, no display at all, and the interior lights won't come on at all.
    I tried jump starting the car - nothing happened!
    I am sure the car had plenty of gas, but I put in 2 more gallons anyway. Dead as a doornail.
    Do I replace the 12V?
  2. Patrick Wong
    18,200
    6,491
    Yes. It sounds like the 12V battery is close to dead since you say the interior lights are weak.
    Also, there probably is something wrong with your jumpstart process. Perhaps the jump cables are faulty, or perhaps the donor battery has insufficient power.
    When you hook up good jump cables to a strong donor battery, then when you open a door to your Prius, the interior cabin lights should appear bright, and the Prius should become READY when you try to start it.
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Yes.
  4. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Your 12V is toast! Hal
  5. PriusTick
    Thank you for the responses. Apparently I have to wait until Monday, the batteries are only sold at dealers (In Texas, dealerships are closed on Sundays). I see better batteries online, but I just don't have the patience to wait.
    I will try jump starting again tomorrow with a different setup just to make sure.
    Thank you again.
  6. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I really hope your jumpstart process was good. It's amazing how often we get stories here of people who's only problem is a flat 12V battery but because of a miss attempt to jump start it they end up with major issues.
    Hopefully your jump start only failed because the 12V battery was so bad that it wouldn't let the voltage rise enough to boot. That situation would be pretty rare though.
  7. richard schumacher
    7,664
    1,042
    United States
    If the 12V battery failed in such a way as to prevent a jumpstart (that is, an internal short) you can remove the 12V battery and then jump start the car. Once started the 12V battery is not needed. Of course having done this you would then drive straight to a dealer and not shut off the car until immediately before installing the new battery.
    As with every other modern car make damn sure that you have the polarity correct when jumping. If the polarity is wrong it will need a tow to a dealer, and if you're lucky the only damage would be a blown fuse.
  8. PriusTick
    I am positive (no pun intended) that I attempted the jump correctly. I have jump started multiple times on other cars and I looked through the forum to see the differences in setup on a Prius. I bought a new jumper cable as the previous one did look a little cheap and I will try again tomorrow.
    If it doesn't start, I will remove the battery and try again.
    Thanks all.
  9. Kutanks
    Kutanks Member
    118
    MA
    time for a new battery, personally i think its really stupid of toyota to hav made the battery so small, i know it doesn't need to be that big but i get shitty mpg because i chill in my car all the time. I have to leave the engine in ready mode or the battery will run down. How much weight savings did they really achieve anyways?
  10. PriusTick
    Ok, one more question. How do I get into the trunk if all the electronic key stuff is broken!?!?
  11. Hal W
    Hal W New Member
    872
    53
    Crawl into the back and remove the spare tire cover and where the lock is in the hatch you will find a a rod to pull too release the hatch. I would connect power to the front [jump start connection]and use the fob, Hal
