What happens at 63mph?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jrmgkia, Nov 18, 2011.
  1. jrmgkia
    jrmgkia Wish I was cycling
    53
    Campbell, CA
    Maybe this has been answered but I can't find it anywhere, if it has been answered please just refer me to the correct thread.
    The PiP literature says, "it’s capable of traveling up to 62 mph in EV mode."
    So I am wondering what happens at speeds >63mph? Does it run in normal hybrid mode? Does it still use the hybrid battery to increase MPG and reduce SOC of battery?
    For example lets say I jump on the freeway with a fully charged PiP and I drive 15 miles with the cruise control at 65mph.
    When I exit the freeway do I still have a full charge on the battery?
    Would I get the same MPG over those 15 miles regardless of whether the battery was fully charged or fully depleted when I got on the freeway?
    What would change if I had set the cruise control at 62mph for the 15mile drive?
    So many questions...:confused:
  2. krishkal
    krishkal New Member
    Fremont, CA
    My expectation is that it will automatically kick you out of EV mode at that speed, and go into hybrid mode, which means battery will still be used along with the gasoline engine.
  3. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    It will make the car run in regular hybrid mode, like a regular Prius. If you had a charge left in the EV battery when the kickover happens, it'll be there when you go back into EV mode, maybe more if you recharged some going downhill etc.
  4. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    It spontaneously combusts. :flame:
    Just kidding. Probably the same thing that happens in my Volt at >75mph. The engine seemlessly kicks in, and other than the additional noise under the hood it is not different at all. I think the major difference will be since the PiP is similar to a regular Prius you will get the mechanical coupling of the engine into the drivetrain, and associated slight jerk that is not present in the Volt. I certaintly wish you guys luck, and I cannot wait to hear how everyone likes their PiP's. You guys know yet when you are expected to take delivery? I know they just opened the pre-orders...
  5. cliffmark1
    cliffmark1 Junior Member
    39
    us
    How do you like the volt compared to let's say a cts?
    DROIDX ?
  6. Roadburner440
    316
    59
    Hampton, VA
    I had a Cadillac Eldorado before (1998), and I think the Volt is a far better car than that.. Compared to a CTS though I am unsure. The only CTS I have ever driven was the V model, and of course the Volt does not compare to that car. I imagine compared to the base model it is nicer. Everything in the car except the steering wheel controls, and the radio volume/tune knobs is either touch sensitive or a touch screen. So feels very futuristic. Cadillac is coming out with their own version (the ELR), so I imagine that will blow the doors off the Volt.
  7. Roadburner440
    316
    59
    Hampton, VA
    Guess a better comparison is against our Prius so this thread stays somewhat on track, LOL.. I would like to meet up whenever someone in my area gets a PiP so we can see actual plug in to plug in. As I like our Prius a lot as well. Especially since it is more efficient gas to gas with the Volt (our best average in the Volt is 42mpg, best in our gas Prius is 60mpg). Here you go though, the big pictures. Not sure how many of you that ordered a PiP have a Gen3 or not, but here is the comparison of a regular one with the competition.
  8. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    It turns into a Ferrari!
  9. jrmgkia
    53
    Campbell, CA
    :focus:
    I'm curious where you found this information, do you have a source?
    P.S. I love the Volt, I think the Volt will be our Prius replacement rather than the PiP, but I want to better understand the PiP before I make a decision. Thanks
  10. drees
    drees Senior Member
    1,782
    247
    The Volt only kicks the engine on in these situations:
    1. Battery is empty (or start getting low and you're mountain mode)
    2. If you want heat and it's really cold out.
    3. It decides that the gas in the tank is getting stale so should burn some off.
    And then once the engine is on, it only uses the engine to directly help propel the car under heavy load and/or high speeds (because of this performance is slightly better once the battery SOC is low and the engine is running).
    Otherwise it never uses the engine to assist regardless of how hard you're pushing on the accelerator.
    Quite a bit different than the PIP which must run the engine at > 63 mph and if you push too hard on the accelerator though I expect the end result in terms of gas and electricity consumption will not be that different in many driving cycles.
  11. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    I've driven the car, was at the press conference for its debut at GDE in SF in September and was given the demo car for a week a year ago.
  12. Roadburner440
    316
    59
    Hampton, VA
    4. Open hood with car switched on. Scared the crap out of me the first time I did it when showing someone the car.
    I have not personally had the engine come on when requesting heat in cold weather. I wished that it would come on. Maybe it just has not been cold enough yet. I imagine the PiP's heater will be better than the Volt's, or at least I hope so for all you guys sake.
  13. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    The real magic happens at 88 mph. :)
    2 people like this.
  14. Piprius
    Piprius Member of the cult of Prius
    72
    MD
    Damn your eyes hyo. I was fighting the urge to say something like
    "Depends if you have a flux capacitor or not" or
    "8.1 jigawatts!"
    Glad to know I am not the only one who imagined the same response.
  15. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Gotta be quick. :p
    I was just thinking 'How is it possible no one said that yet?' :)
  16. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    That guess is the correct one. This sequence of photos captured while driving an early model PHV confirms the MPG boost:
    In other words, the engine spins at the speeds above the threshold but no where near as much fuel is consumed as normal. On my 16.5 mile commute with about 9 miles at 70 mph, the result was 166 MPG.
    Of course, there's a EV/HV button with the production model. Offering a choice of when to boost could provide the opportunity for even higher MPG... when used wisely.
  17. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    It is with some level of humility (though not much) that I concur with Paradox in that Toyota gave some of us the prototype version to drive around for a couple weeks. Here in Chicagoland, I was on at-grade roads as well as on the interstates.
    The only point I would care to correct is that from RoadBurner concerning the kick or jerk during the switchover. I would need confirmation of this before I would believe it. The prototype I drove was smooth and seemless as was the production version I drove at Green Drive Expo a couple months ago.
  18. Roadburner440
    316
    59
    Hampton, VA
    Was just speculation on my part from having my regular Prius. Really does not detract from my experience to much, but it is something I know notice going from the Volt back to our Prius. Slight, but is there. Granted the Volt vibrates whenever the gas engine is on and that is annoying as can be. Especially the first time it kicked on and you could feel it through the steering wheel & brake pedal. I thought something was wrong with the car... Hopefully the engine couples smoothly in the PiP. Never even seen one so to be honest I have no idea.
  19. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Production version would not blend on the highway? The ride in your loaner prototype did blend and depleted the charge boosting the MPG.
  20. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    This is mostly correct but there is a common misunderstanding on when the Volt mechanically connects the gas engine to the planetary gears (and therefore the wheels) when the battery is at the minimum State of Charge and the car has switched into Charge Sustaining or "hybrid" mode.
    Intuitively, many think that this mechanical linkage occurs under heavy load (torque demand) to help the electric motor move the car. Actually, the opposite is true. Under 75 mph or so, the gas engine is mechanically connected only when torque demand is low such as fairly constant speed driving between 40-75 mph. Under heavy torque demand like sudden strong acceleration, the Volt disconnects the gas engine from the planetary gears and uses the large electric 149 HP motor alone with power supplied from the battery and from the gas engine connected only to the smaller motor/generator.
    It is essentially impossible to tell when the Volt mechanically links in the gas engine without having diagnostic equipment plugged into the OBD-II port. It is, however, possible to notice a momentary delay when requesting sudden acceleration when the gas engine is already mechanically connected. The delay of disconnecting the gas engine feels similar to an automatic transmission kicking down to a lower gear under similar circumstances.
    As long as there is battery charge remaining above the minimum level, the Volt never uses the gas engine while driving except for 1-2 minutes occasionally at temperatures under 26F to assist heating, when it determines that the average age of the gasoline in the tank is over one year, or for 1-2 minutes every 6 weeks if the engine is never otherwise run.
    In other words, the gas engine is effectively only used when the battery runs low or when temperatures are under 26F.
    Here is a good concise description of the Volt powertrain at a GM technical training blog site:
    http://www.sandyblogs.com/techlink/2010/12/voltec-electric-drive-unit-and-high-voltage-battery.html
    2 people like this.
