What hurt is done if car is left on overnight
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by peterpanusa, Sep 5, 2011.
  1. peterpanusa
    peterpanusa New Member
    california
    I know it is going to happen sooner or later.
    We drove home last night, pull in the garage and hit "Park" button, but forgot to hit "Power" button. The key is left inside the car, and lucky (or un-lucky, that we could tell by the noise) that we did not turn on the radio, headlight is turned off.
    This morning, we found the car still in "Ready" mode.
    So is there any hurt, such as the 12V battery, etc ?
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    No hurt to the car. But you could hurt or kill yourself or family by leaving it on while in a garage since eventually it will cycle on and off producing carbon monoxide.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    You can avoid this by just pressing the Power button to turn the car off--which also puts the car in park, so there's no need to first press the Park button.
  4. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    No harm, but, as was already mentioned, can be a safety hazard.
    I second the idea of using the POWER button instead of the PARK button. Take that moment before you jump out to look at the dash to make sure all the pretty lights are off.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Obviously you will burn a little gasoline.
    Tom
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    the car itself consumes more power while sitting on than the radio.. or headlights.. or any of that combined. you probably burnt about a gallon. if the climate control was off, it's about a gallon every 12 hours.
  7. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I agree with stream. Get use to pushing the Power button rather than the Park button while shutting the car off.
  8. ETC(SS)
    6,841
    I'll make it unanimous (so far.)
    No harm done to the car.
    If you're apt to do this again, you may want to get and use a carbon monoxide detector for your home and for the garage.
    Like others, I use the POWER button to shut down the car when I'm finished with it instead of Park + POWER.
    YMMV.
    Good Luck!
  9. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Get in the habit of hitting the power button instead of park button AND lock the car. You will be unable to lock it if it's not shut off. Two safeguards to ensure it doesn't happen again.
  10. offroader
    offroader Junior Member
    44
    Not sure if this helps but I alway keep the key inside my pocket and lock my doors.
  11. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    As others have said the big hurt could be to you or others in the house, especially if there is a bedroom adjacent to or above the garage. I'd second the call for a carbon monoxide alarm - it is $25 or so well spent.
  12. qbee42
    18,058
    3,076
    Northern Michigan
    Always locking your Prius is a good idea. I live in an area where locks are unnecessary, but I always lock my Prius. Locking is a quick and effective way to ensure that all doors are fully shut and the Prius powered down. If not, your Prius will beep and refuse to lock.
    Tom
  13. daniel
    14,487
    1,519
    Spokane, WA
    FWIW, the car can be locked while on if you use the physical key, rather than the door button or the fob button. This is useful for heating the cabin in bitterly cold weather.
    Damage to the car by leaving it in Ready would be if you were low enough on gasoline that the car ran out of gas, and then the traction battery became depleted.
    Develop some kind of routine, whether it's always using the Power button, as some have suggested, or always locking, as others have suggested, or keeping the fob in your pocket, whatever. But get into a habit that becomes second nature, to make sure you always turn the car off. I believe that if you have the fob in your pocket and you close the car door from the outside, the car will beep at you if it's still on.
