What is highest speed to use engine Brake?
Discussion in 'Gen 3 Prius Technical Discussion' started by jgrode1, Nov 17, 2010.
  1. jgrode1
    jgrode1 New Member
    This would be helpful for exiting the freeway... unless it is bad for my gen III. Thanks, Jim
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    No speed limit on "B" mode. Engine RPM is controlled by the HSD. It won't let it over-rev.
  3. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    It's been posted before that "B" mode should only be used for long downhill grades where the brakes are being used. It forces the ice to run thus wasting gas.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Any speed is okay, but why would you want to use it for that purpose? Press the brake pedal and recapture more of that energy.
    Tom
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I have used B mode at 85 or 90 MPH coming down long steep mountains with a full battery. The car will protect itself and will not go beyond the 5200 RPM red line. I have seen it up to about 4800 in B mode however.
  6. theloop82
    theloop82 Member
    Spanaway, Wa
    It really is counter to everything my dad taught me about hills and slowing down from high speeds. Then again, from driving behind (and smelling) people who don't have regenerative braking, I don't think alot of people know that you can smoke your rotors by riding the brakes down the pass.
  7. tumbleweed
    4,067
    692
    Eastern Oregon
    The Prius requires a little different technique. But as others have said there is nothing to be gained from using B unless the battery is full, or unless you know the road and are sure it will be full before you get down the hill.
    With proper use of regeneration I think our friction brakes will last for a lot of miles.
  8. theloop82
    theloop82 Member
    Spanaway, Wa
    Ive found if you use the cruise control when you are going down a long grade, it will use regenerative braking until the bars are full, and then it will automatically use engine braking.
  9. tumbleweed
    4,067
    692
    Eastern Oregon
    Yes I've see that also, good feature I think. Probably means we don't really have to select B, we can do it with our foot.
  10. greenewl
    greenewl New Member
    Ka'a'awa, HI
    I agree B for steep downhills, generally brakes are cheaper than CVTs!
  11. qbee42
    18,058
    3,079
    Northern Michigan
    Your Prius doesn't have a CVT in the mechanical sense, so you don't need to worry about that. While your assertion is flawed, your conclusion is correct.
    Tom
