What is part number for rear wheel hub mounting bolt?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by anonymous, Jul 7, 2023.
  1. anonymous
    anonymous Member
    177
    98
    US
  2. Tombukt2
    Tombukt2 Senior Member
    11,563
    2,033
    Durham NC
    You should be able to walk something like that into Fastenal I would think see that little shoulder and all in a pinch you could do without one with the shoulder and one hole I wouldn't do it more than that and folks here are probably brown themselves thinking about that but I've done it a bunch of times not in prii. Never had a problem in 25 years It's about how long they've been using these little shoulder bolts that go in to hold the hub bearings in so there's that there's also walking to the junkyard like LKQ and go look at the back of Yaris Corolla Prius I think some sienna van etc You won't be there long You just have to go and look at the back of the vehicles and where anybody has taken apart the rear suspension on some of these vehicles you may see the suspension pieces laying flat on the ground where you can take your 12 mm socket or the proper socket and take the bolt out take an extra seems like you may need it and off you go If you really want the part number personally I'm not going to go try to look it up but if you go on Toyota site should not be a problem If you can't navigate that for whatever reason call your parts department at Toyota tell them you're replacing a bolt that holds the rear hub to the suspension and they will give you a part number that they probably don't have in stock but at least you'll have a part number I wouldn't want the part number I just want the bolts the easiest way for me to get it quickly is to shoot over to LKQ they'll be thousands of them maybe tens of thousands as they're used on so many vehicles If you have one in your pocket you will see how many you can probably find on the ground if you look at the rears of all the cars don't go to the front just the back.
  3. Mr. F
    Mr. F Active Member
    386
    251
    Washington
    90119A0350
    anonymous likes this.
  4. anonymous
    anonymous Member
    177
    98
    US
    Ok so that's the one, I guess they just have washers now
    Mr. F likes this.
  5. Tombukt2
    11,563
    2,033
    Durham NC
    I guess so if that's what Toyota gave you If you have one of the other ones out and you can show it to the Toyota parts person sometimes that goes a long way with nuts bolts and some fasteners looks like that will work no problem but the other seem to have a tapered shoulder or something or a small short shoulder as if to help the guide the hub flange straight with the hole for what reason I don't really know It's not like this thing is not hub centric or something It only can fit in the hole that goes in the whole hub that is and then the bolts in their respective threaded holes so I'm not sure why the original had that little tapered shoulder there
