What is the fuel consumption of the Gen 3 when the ICE idles?
Discussion in 'Gen 3 Prius Fuel Economy' started by pakitt, Jan 23, 2010.
  1. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Does anybody know what the fuel consumption of the ICE is when idling (e.g. during warm up?) - how many L(gallons) per minute/hour?
    My Polo used to display this information when standing still - 0.6-0.7L/h was its value.
    On the Prius Gen 3 if you start the car, set trip to 0km and it starts warming up, the fuel consumption shows 0L/100km (rightly so) but the average goes to 99L/100km, right as well. The true is that ICE idling when standing still does increase the fuel consumption on average - but how much exactly?
    On my commute - I am trying to estimate hoe much each minute I am standing still with the engine idling (due to cold weather) is affecting my average fuel consumption.
    And I tell you, from what I see, standing still a couple of minutes at most, already moves my average over 17km leg, of 0.1-0.2L/100km.
  2. fuzzy1
    10,332
    I haven't watched this on the Prius, but suspect that it will be quite variable during the warmup cycle. Will have to remember to check it sometime.
    For reference, my 2.5L Subaru starts at 0.8 gallon/hour, declining to 0.3 gal/hr when fully warmed.
  3. bwilson4web
    15,939
    You might consider parking the car with something on the trip meter and calculate the fuel burn. The next day, start the car and wait for the idle warm-up to complete. Use the updated reading to calculate the fuel burn. Subtract the two.
  4. dogfriend
    7,512
    1,188
    Carmichael, CA
    You are correct, Sir.
    I have GPH (gal per hour) as one of my Scangauge choices and the rate varies drastically during the warmup period. It also varies depending upon how you drive away during the warmup period (I typically start to move before the ICE fires up).
  5. fuzzy1
    10,332
    Some Prius numbers this morning:
    At startup, 39F, 0.68-0.72 gal/hr (it actually started at about 0.62, then rose after moving out of the parking space);
    80F, 0.44 gal/hr
    100F, 0.35 gal/hr
    130F, 0.30 gal/hr just before the first AutoStop. Hitting the defrost button forced it back on at 0.31-0.32.
    After that, AutoStop prevented any more idle measurements.
    I was surprised to not see any smaller numbers than my larger non-Atkinson Subaru.
    2 people like this.
  6. Rhino
    Rhino New Member
    460
    U.S.A.
    Of course, in the real world, an idling Prius would not be idling 100% of the time like the ICE only Subaru. So the actual consumption per hour should be less.
  7. pakitt
    2,173
    1,313
    Colorado
    Are these numbers of the Gen3, right? if so, thanks a lot!
    The numbers did change a lot also on my Polo - when it was cold it would start at 1L/hr and then stabilise to 0.6L/hr when warm. 0.5L/hr when outside temperature around 25C, no A/C on (that could raise the consumption of about 0.1L/hr)
  8. fuzzy1
    10,332
    Yes, my Prius is a GenIII.
    My Subaru burns more fuel in a fully warm idle than your Polo burns during a cold starup. :eek:
    The Subaru burns about an extra 0.2 gal/hr when the AC compressor clutch kicks in, but I have never measured its duty cycle to learn what fraction of the time it runs.
  9. Tideland Prius
    16,408
    Why is 0L/100km "rightly so"?? If it's idling, it should be showing 99.9L/100km (or in our case, 10L/100km since that's the upper limit of the digital display next to the speedo). You're burning an infinite amount of litres of fuel to move 100km because you're not moving at all.
  10. odaigle
    odaigle New Member
    35
    Canada -- Montreal
    I guess you should put the car in neutral (N) before making the measurement. When the car is in D, B or P and the ICE is "idleing" (not powering the wheels, car stopped), the ICE is not idle at all: it recharges the battery. And while it does so, it provide lots of power to MG1. Thus, the ICE is using more gas than a normal car would use when stopped in D, B or P. But it does not waste it, as compared to other cars.
  11. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Hence why the requested measurement was units per time vs. units per distance.
  12. Tideland Prius
    16,408
    Yeah but I was confused when he said 0L/100km instant is correct and so is the average of 99.9L/100km. Shouldn't the instant should 99.9L/100km too? I actually hate the fact that the bar goes to 0 when idling because it's false advertising (no, you're not in EV mode) and second, it's harder to notice the engine noise (I have to pay close attention) so it's harder to know if the engine's off or not. If the bar showed 99.9L/100km (well 10L/100km since that's the top), then if it goes off, I know the engine has shut off.
  13. fuzzy1
    10,332
    For some reason I hadn't previously thought to check in N, but it does lower consumption when this prevents battery charging.
    Today I didn't try N on the dead cold engine. At room temperature, it pulled 0.50 GPH. Then it fell to 0.33-36 over a wide range of different partially warm temps, and 0.20-22 when fully warmed. There could be an offset in there, as my Scangauge sometimes displays a 0.02 GPH during autostop, instead of 0.00.
    I'll have to watch several more warmup cycles to see if there is more detail to be recorded.
  14. quantumslip
    quantumslip Member
    149
    Sugar Land, TX
    hmm, i can see why the prius can be used as an emergency fuel generator now. could last a good while with the engine turning on and off
  15. odaigle
    odaigle New Member
    35
    Canada -- Montreal
    I agree. It is stupid to fall at 0L/100km when we are at infinite L/100km. But I guess some people would complain to Toyota that their car is inefficient when it is stopped at a red light when they would see their IFC topped at 10L/100km. It would be cool to switch to L/hr when we are below a given speed (5 km/h or so), like some cars do.
  16. pakitt
    2,173
    1,313
    Colorado
    I said that 0L/100km is correct, because the instant fuel consumption shows consumption per distance travelled. If you are standing still you are not having a consumption to move the car. Hence 0L.
    But it is also counterintuitive to hear the engine run while at a traffic light and see the instant fuel consumption to 0. It should have changed more correctly to L/hr, which is what for example happened in my Polo when the speed was less than 2-3km/h.
    The only way to know what the fuel consumption is when stopping and the ICE idles is to use the ScanGauge that I don't have - hence my question.
    That one needs to look at the average fuel consumption to understand that when the engine is running while you are standing still you *are* consuming, is a bit of let down for a car with a multifunction display and high tech engine like the Prius.
    MPG is a good way to show instant fuel consumption. You don't move, the FE goes, "rightly so", to 0MPG. If Toyota had used km/L there would be no problem, but then you would still not know exactly what is the fuel consumption per hour is, when you are standing still and the engine is idling...:rolleyes:
  17. pakitt
    2,173
    1,313
    Colorado
    Fuzzy1, based also on your other post, it means that the Prius does on average, when not fully warm, 0.35gal/hr = 1.3L/hr - that's a LOT!
    If it is 0.2gal/hr = 0.7L/hr that is more normal. My polo would start with 1L/hr when fully cold and settle down to 0.6L/hr. Considering that the Prius ICE is charging the battery, the extra 0.1-0.2L/hr is understandable - but if on average is 1.3L/hr - that is really too much!
    If you have a 20 min trip with average of, say, 4.8L/100km over a 17km stretch of road, I have calculated, with 0.8L/hr with the ICE idling standing still, that is 0.013L/hr, that if you stop 1 min idling (21 mins overall trip) the fuel consumption is raised by 1.6% - if you add 5mins total idling, 7,55% more fuel consumption; if you are staying still for a total of 10 additional minutes (really *bad* day traffic with 10mins standing rock still, that is!), total travel time 30mins, you consume, due to idling engine, 14% more! (you move from 4.8 to 5.58L/100km). If it is cold, likely the 0.8L/hr might not be the right value and possibly higher - maybe 0.9-1L/hr (I cannot image it is more than this!).
    More investigation from those with the right tools would be appreciated...pleeeeeeaaaase :)
    My calculations might be wrong...!
  18. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    In the evening it is a low speed run through the parking lot to a traffic light. Waiting at the light I've seen up to .7gph (2.6 lph) but it is not constant. Generally I'd say the range is mostly .5-.7gph (depending on the OAT) but it swings up & down every few seconds.
  19. fuzzy1
    10,332
    If I just compare effective intake displacement against my Subaru, this Prius does seem to burn a lot of fuel while idling.
    But others have pointed out that during cold idle, it is configured to produce extra heat, so this would consume extra fuel. And I find it doesn't idle for long, certainly not 5 or 10 minutes.
    I have two choices for the start of my commute route. On the steep descent route, down a 130 meter hill, the last idle occurs at the 2nd stop light at about 4 km. The other route has much less descent, so the last idle occurs at the 5th light, at about 2 km. Beyond those points, the engine has been warm enough to go into AutoStop, so it burns no more idle fuel.
  20. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    This is not correct. While standing still, if you are burning any fuel the L/100km rate is infinite. This is because you could idle there forever at zero speed without ever covering the 100km. Another way to look at it is the distance traveled is zero, so the denominator is zero. If the numerator is non-zero, which it is with the ICE running, then you have a finite number divided by zero, which yields infinity.
    If the ICE is off, then the fuel burn is zero. Standing still with without burning fuel yields zero divided by zero, which is indeterminate.
    Tom
