What should tranny fluid swap/clean and inverter coolant replace cost?
Discussion in 'Generation 1 Prius Discussion' started by tposs001, May 17, 2012.
  1. tposs001
    tposs001 Junior Member
    30
    Miami, Fl
    2002 Prius
    I
    I want the service done by a shop but I wanted to get some figures on what some of you have paid for it to be done. Id like to knock it out in one shot.
    Is there a general price guide to go by?
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Somewhere near $100 for a Gen 2, parts and labor for the transaxle fluid change.
  3. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My dealer charges $100 to do an ATF Drain/Refill in a Gen2. There is a bit more work to do it in a Gen1 (drop the pan and clean it, requires a new gasket) so maybe a bit higher price.
    JeffD
  4. dswi
    dswi Junior Member
    31
    Greenville, South Carolina
    2001 Prius
    Dealer just charged me $150 to do the inverter coolant drain/flush/fill. I did the transaxle fluid myself...really easy. Dealer did the engine also as a courtesy. 2 for the price of 1!!
    MAKE SURE TO USE TOYOTA FLUIDS!!! Coolant is di-electric.
  5. Mike500
    Mike500 Senior Member
    2,593
    766
    Which dealer? I'm in your area.
  6. beanmat
    beanmat New Member
    22
    New Port Richey Fl.
    2003 Prius
    Had a Tranny serf. done by my Favort. mechanic and paid $ 68.00 & got him the parts from my nearest Toyota dealer oil incl. for about $ 57 or so , see my post .
