What size wheels will fit on 2010 Prius II
Discussion in 'Gen 3 Prius Accessories and Modifications' started by tainacious, Nov 3, 2010.
  1. tainacious
    tainacious New Member
    El Cerrito, CA
    I just bought a 2010 Prius II and was wondering what size wheels will fit on it. What is the minimum offset I can go with a 17x8 without having the tire scrape the fender when I turn the wheel all the way to make u-turns? Any other suggestions on sizes or things I should keep in mind?
    Thanks!
    Tai
    p.s. loving my Prius :D
  2. andino
    andino Senior Member
    746
    550
    San Jose, CA
    You shouldn't have issues with rub at any offset if you're not lowered. However, I would probably stick to +45mm if you don't want to do any work rolling fenders and such.
  3. kewrad
    kewrad New Member
    Maryland
    Do you think that the 2010 Corolla XRS 17"(five spoke wheels) will fit in a 2010 Prius II? My biggest question is the offset issue.
