what toyota said about tires
Discussion in 'Newbie Forum' started by shotsy, Jul 25, 2007.
  1. shotsy
    shotsy New Member
    hey, newbie here. 1 week old 2007 prius mag grey, pkge #2
    had nail in tire, had to get a new one (too near sidewall) :(:(:( toyo said my other tires were too high (43 front, 41 rear) and that this would be dangerous and wear out my tires quickly, thus causing not only danger but expense. they reset them to the specs on the door. any ideas about this ? am taking a long trip from san fran to northwest and do want to be safe.
  2. daronspicher
    daronspicher Active Member
    1,208
    I run mine about 40... 38.. maybe 41...
    Have 58,600 miles on the originals and heading to about 70k before I think I'll have to change them out.
    So far, so good, so safe... I can't recommend or tell you what to do, but I've been doing well on them with this 'closer to tire spec max' than the original toyota 'spec'.
  3. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    This is one reason I have an air compressor in my cargo area. When I suffered a construction screw, the repair guy regrettably said that he could not exceed the pressure rating on the door. I understand. Like catgic said, he's just following orders.
    But I only drove about 100 feet on that pressure before turning into another parking lot and inflating the tire to where I wanted it.
    I should add: where I got the tire fixed, they routinely check the wear on every tire. They all showed equal and were in good condition. Except for the one being repaired because it was actually a slow leak and I had driven on it for about a week before noticing. When I brought it in, it was deflated down to 35psi. ;)
  5. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(harperlee @ Jul 25 2007, 02:38 PM) [snapback]484824[/snapback]</div>
    I routinely take a 500+ mile trips on the interstate each way and run at 42 front 40 rear on the stock Goodyear Integrities and so far no problems whatsoever, no visible wear problems either. It does make for a slightly rougher ride, but even at the "recommended pressure" the Prius is not very gentle.
  6. JoeMagnusson
    JoeMagnusson New Member
    Flower Mound, TX
    I take my car in for oil change every 3000 miles and have the tires checked and rotated like a good little do-be. My tires lasted 25,000 miles I was sure glad they had ExtraMiles warrenty on them. I don't know what brand they where but I did expect them to last longer then 25,000.
  7. Tideland Prius
    16,402
    Mine's at 38/36 and the edges are still wearing out.... >.<
  8. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    HarperLee,
    It's Boo. And I also own a 2007 Magnetic Gray Prius Package 2 (sometimes called Package 3 or other number depending on where and when you are on the Toyota website). Guess the apple doesn't fall far from the tree.
    I think you know that there are a lot of threads and posts on PriusChat regarding the best tire pressure for the Prius tires. But if you don't, then you should check them out. They are all in line with the replies you've received so far.
    Specifically regarding the "dangerousness" aspect of the different tire pressures, I don't think that's a factor for either the factory recommended tire pressures or the higher "PriusChat" tire pressures or the points in between.
    A more important issue regarding "dangerousness" is the experience that a lot of PriusChat owners seem to have had with the OEM Integrities themselves -- they don't seem to handle well under any conditions, and seem especially dangerous in rain, snow and ice. There are numerous posts here about skidding, sliding, and hydroplaning with the Integrities. A lot of PriusChat members replace their Integrities (even if they're brand new or near new) with better rain, snow and ice handling tires like the Goodyear Assurance TripleTred, Goodyear Comfortred, Michelin HydroEdge, etc. I, for one, am getting the TripleTreds installed this week, even though there are only 1000 miles on my Integrities.
    Still looking out for you after all these years.
    --- Boo Radley
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    There are many different points of view. I am very suspicious of alarmist statements. According to Goodyear your tp is in spec. IMO the only thing in danger when running a higher tp is the profits of the tire salesman. Harder tires last longer and provide higher mpg. In all honesty I need to develop the habit of checking the tp before leaving the dealer's lot. The only time I found my tp low was after a trip to the shop.
    45psi works for me. Inflate the tires to provide the combination of ride, handling & economy that you are happiest with.
  10. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(JimN @ Jul 25 2007, 06:21 PM) [snapback]485145[/snapback]</div>
    Well said, Jim.
    The tires last longer, run cooler, are more efficient, and HANDLE BETTER, IMO.
  11. shotsy
    shotsy New Member
    <div class='quotetop'>QUOTE(Boo @ Jul 25 2007, 03:48 PM) [snapback]484951[/snapback]</div>
    Boo,
    don't know if i pressed send on last attempt to reply...so good to hear from you after all these years. saw scout a few days ago and she still looks good, younger than springtime...
    oh yes, about the tires. I will take your advice and increase pressure, sounds like the toyo guy was just doing his job as instructed. they gave me stinky eye when i said "but on priuschat..."
    I will also consider changing to different tires. thanks for the suggestions. I am loving this car and never thought of myself as a sedan person, having traded a crv for a jetta wagon, worst milage ever so traded for mag grey. The grey girl seems to have just as much room in back for dogs and stuffand got a hammock thing for the dogs to save seats and floor in back, looks good. since i live in pacifica, foggy, grey, moist wet roads all summer i think tires with better traction are a real consideration.
    stay well boo, and thanks, check the tree out front. best, harperlee
  12. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 25 2007, 04:28 PM) [snapback]484922[/snapback]</div>
    Take a close look a brand new Integrities and you will find that the center grooves of the tire are about twice as deep as the grooves at the edge of the tires. Therefore if the tires were to wear evenly across their surface, the edges would go bald long before the center.
    I think all these people who report "excessive" edge wear at 25-30K miles never paid attention to the relative depths of the grooves until the point when the edge grooves were getting obviously shallow. They then look at the difference in depth between the edge grooves and the center grooves and assume the difference is due to uneven wear, rather than the fact that they were manufactured that way.
    I don't know why Good Year designed them this way, but they did. If you don't believe me, just take a trip to your local Toyota dealer and look for yourself. Or look at your existing tires with the "excessive edge wear". You will notice that there is a drop between the bottom of the edge grooves and the bottom of the center grooves. If the grooves had all started at the same depth, then the bottoms of the edge and center grooves would all be at the same level with no change when you move from the edge groves to a center groove.
  13. clinster
    clinster New Member
    I just bought 2008 Pruis with 17 inch wheels and low profile tires factory installed,,looks great...anybody have the same and what tp should they have?
