what's the most accurate way to determine MPG ?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fortytwok, May 6, 2013.
  1. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    short of getting a fill-up which I don't plan on doing for 6 mos ;-)
    I've kept track of miles after my PiP kicked out of EV
    but the few times ICE activated it added miles to the PiP's reading
    I don't trust that reading by the way. I'm just two bars down on my gas reading and believe I've only used 2 gallons.
    OR
    The Range reading ?
    I started at 520 on my PiP and now about 400 (thus my feeling that 2 gallons is about right)
    50,805
    i think you're only guessing until you fill up. and even then, you need a few tanks to average because you can never fill up to the exact same point every time.
  3. 3PriusMike
    3,065
    2,399
    Silicon Valley
    I'm guessing that every one of the displayed numbers are based on the same fuel consumed measurement based on drops of fuel consumed. How would it be any different?
    Mike
  4. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    I bought a scangauge e from amazon. It is very accurate.
  5. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Thanks I'll look into the details on that.
    This isn't a huge deal, once I get a fill-up I'll have pretty accurate numbers but to answer Mike - my feeling is the PiP guages are not correct (or if one is I'm not sure which) as they're giving conflicting info.
    For example the gas read now says 168 miles used - yet I'm down just 2 bars and the range is down just 120 miles.
    all good though just hit 1500 miles - 88% - est 2 gallons
    going for that 3,000 tank target !
  6. stanwagon
    stanwagon Junior Member
    64
    2013 Prius Plug-in
    Agreed that the fillup is the best way to calibrate. I just filled the car up for the first time (it came with only 2 gals because of truck transport, so this is not my true first fillup) and I noticed that the fuel gauge went down one square after about 45 miles, half of which were EV. This seems odd but at least the mpg indicator tells me that I am doing much better. Typically in Prius (e.g., my 2005) the first square would not disappear until 100 miles sometimes. So it seems that the fuel gauge continues to be highly nonlinear, though now it is in the other direction.
    One does wonder why technology is not used that tells exactly the fuel content of the tank. It can't be that hard....
  7. El Dobro
    El Dobro A Member
    7,071
    3,258
    Truck transport?
  8. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Both range (EV and total range) gauges are just estimates and can vary quite a bit. Miles traveled on the odometer is very accurate. The trip summary screen can vary a bit bit doesn't affect the odometer so always go by the odometer reading when in doubt.
  9. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Maybe an out-of-state purchase?
  10. El Dobro
    El Dobro A Member
    7,071
    3,258
    He said he had 2 gallons left after truck transport. 8 gallons were burned on the transport?
  11. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    The PiP was dragging the truck ;-)
    kenoarto likes this.
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    The range readout is an estimate based on your current mpg. I've driven up to 25 miles with it reading zero. You can't rely on it for consumption calculations. Use the EV Ratio screen. It's only accurate to the gallon (no decimals, it always rounds down) so it's not too useful to you until you've used a lot of gas or you can do error bars in your calculations.
    I've never reset either of my EV ratio screens and they currently read 153 gallons. So I've used between 153-154 gallons for the distance shown on my odometer.
  13. stanwagon
    64
    2013 Prius Plug-in
    El Dobro: Yes, it was an out-state purchase. Plug-in not available in Colo so I had it trucked from a dealer in Seattle and am happy with how it worked out. Dealer said that when vehicle is transported by truck they are asked to not fill it up. So I got it with 2 gallons, not a full tank.
    The range indicator seems odd. Right now on current tank it says I have done 90 mpg so for on the tank (I use trip A for that), but my range-to-fillup is given as 480 miles, well under 10 x 90. So range must be based on the assumption that there will be no more EV use. Makes sense for highway driving, but that's about it.
    My goal is to get through to my first fillup with 1000 miles, but the darn "start-on-hill" issue might make that tough. I guess to get that I have to get 50% of my miles to be EV.
  14. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Your total range estimate will be whatever EV range you have (at the time you're looking at the total range number), plus whatever the car estimates you'll be able to drive (on gas only) considering the amount of gas left in the tank.
    If you have 10 gallons in the tank and you've been averaging 48 MPG (on gas only) and have a full charge indicating 12 EV miles, the car's total range would show 10 gallons x 48MPG + 12 EV miles= 492 miles total range.
    Like you said, it would make sense for highway driving.. or more specifically, it would make sense assuming you're not going to charge the car, since the car has no way of knowing when you plan to charge and how often.
  15. stanwagon
    64
    2013 Prius Plug-in
    Yes, of course that makes perfect sense for the Range indicator.
  16. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Just a follow up - I'm convinced more than ever that the PiP guages are off - or at least one of them.
    First tank of gas and I just hit 2350 miles + 91% EV - not disputing those.
    I'm down just 3 bars (and yes it came full) - 212 gas miles which seems about right as it came with 20 gas miles.
    But the PiP is reading 6 gallons used so one of these things is out of synch.
    10.9 gall tank, and bars showing just 30% used... out of be more like 3 gallons, 4 tops - not 6
    Yeah I'll get an answer once I do that first fill-up
    this is my only gripe - loving this PiP purchase
  17. mmmodem
    2,732
    1,703
    Bay Area, CA
    A picture is worth a thousand words. I'm sure someone will be able to answer your discrepancy when you take a picture of your EV Ratio. Make sure you have the ODO displayed at the same time.
  18. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I'll do an updated pic in a bit, but if you look at my sig - there it is - pretty close anyway...
    that was weeks ago but shows the same "down 3 bars" and it shows 90% EV (up to 91% as of today)
    shows total mileage a few hundred less as you'd expect in a couple weeks
    I'll try and take the pic to show the "6 gallons" but I would hope thats not in doubt...
  19. mmmodem
    2,732
    1,703
    Bay Area, CA
    According to your pic, you traveled 147 HV miles on 4 gallons of fuel for 36 mpg. Pretty terrible but I assume it's because you idled most of it away as you have an extremely high EV ratio. 212 miles for 6 gallons of fuel would be 35 mpg so both numbers are on target.
    3 bars should be about 3 gallons. You should show 3 or 4 bars right now if everything is correct. Each bar is a little under a gallon for the PiP. I just filled up 8 empty bars with a little over 7 gallons of gas. So pending a picture assesment, either there is something wrong with your car or someone is adding gas into your tank to play a joke on you.
    The Fiat Mileage Prank | Car Talk
  20. Mendel Leisk
    40,235
    If you can find out the average inaccuracy for PIP, just adjust what the car's telling you by that factor.
    In my case with 3rd gen reg Prius, the average error with about 2.5 years of calculation is 8%. I've heard the PIP error is less though.
