what's the name of this part?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by conorharrison, Apr 7, 2011.
  1. conorharrison
    conorharrison New Member
    NC
    Does anyone know the official name of the part inside of the red box on the attached diagram? Two of the bolts that hold this on came loose and fell off, so I'd like to replace them. Any help is appreciated!
  2. Patrick Wong
    18,200
    6,490
    Although I don't know the official name of that chassis piece, the easiest way to replace the missing bolts is to remove the other two bolts and the bracket, then take one of the bolts to your local hardware store to obtain two matching metric-sized bolts. Good luck.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    38
    Santa Fe, NM
  4. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    From the picture, it looks like this IS the flex plate or stiffening plate isn't it?:confused:
  5. dogfriend
    7,512
    1,188
    Carmichael, CA
  6. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    Yes, this is the factory stiffening plate. Some people replace it with a wider/thicker one of machined aluminum for improved ride/handling.
    The new plate comes with its own attachment bolts, so if you wanted to replace your plate you wouldn't need to find replacements for the old bolts.
    Or you could find someone who replaced theirs and see if they would send you their old bolts if they still had them around. I don't know whether I can still find mine or not:).
  7. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    I have two bolts, if you pay shipping.
    jimpalmeratcableonedotnet
