Wheel bolt pattern and offset of stock Prius V wheels?
Discussion in 'Prius v Accessories and Modifications' started by kanedale, Oct 25, 2011.
  1. kanedale
    kanedale New Member
    San Francisco
    I'm looking to get aftermarket wheels for the Prius V.
    Are the rims a 5 x 100 bolt pattern with a 45 offset?
    - Dale
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    2011 Toyota
    Prius V
    Bolt Pattern: 5x100
    Center Bore: 54.1
    Hardware:12x1.50 Lug
    Offset: 35-48mm
  3. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Aloha and Welcome to PC. I don't know what the bolt pattern or offset is for the Prius v for sure. I would guess the bolt pattern is 5 x 100 like the Gen III, don't want to guess on the offset. The uppercase V in your thread title might be confusing to some you are in the correct forum thought. The Prius v uses a lowercase v and spelled numbers for the trim levels. The 2010 Gen III standard Prius used Roman numerals to denote the trims I, II, III, IV, and V. In 2011 they switched it to spelled numbers also for the Gen III. We all wonder why Toyota named the v the v, it supposedly stands for versatile.
    The 2012 Prius v Two and Three come with, 16-in. 10-spoke alloy wheels with full wheel covers and P205/60R16 tires.
    The 2012 Prius v Five comes with, 17-in. 10-spoke alloy wheels with P215/50R17 tires.
    Knowing the trim level will help you find the correct information you seek.
  4. Mike James
    Mike James Camaros and Prii go figure
    142
    35
    Lincoln, NE
    I am in the same boat as you, looking to purchase a 2nd set of wheels for winter tires. The Prius v (wagon) has bigger wheels than the orginal Prius. I believe they are 5-114, not sure about the exact offset. Just got my v yesterday will measure in the next week.
    Kmun likes this.
  5. toyofixer
    toyofixer Toyota Tech
    29
    Napa CA
    I just looked this up in the Toyota manual it says for the 2012 Prius v
    Bolt pattern 5x114.3
    Inset 39mm for the 16" wheel and 45mm for the 17" wheel
    Hope this helps
    Kmun, vloveride and usbseawolf2000 like this.
  6. Mike James
    142
    35
    Lincoln, NE
    I measured the bolt pattern today, it is 5x114. Backspacing = 5.66" on my 17" wheel. Looking to purchase a winter wheel and tire set in the next few days.:)
    Also the socket size for the lug nuts is 21 mm.
  7. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    Could you give us your OEM tire info for http://priuschat.com/forums/prius-v...-wagon-oem-tire-rpm-speedometer-accuracy.html ?
    If you have a GPS you trust it'd be nice to see speedometer accuracy tested as well. From http://priuschat.com/forums/gen-iii-2010-prius-main-forum/98662-how-fast-have-you-taken-prius.html we found out the Gen III speedometer goes non linear at about 45 MPH as seen in this quote
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Does it say the weights?
  9. dhanson865
    851
    188
    TN, USA
    It appears the OEM 17" tire is a Toyo P215/50R17 Proxes A20
    Toyo isn't sold on tirerack.com and I haven't found the diameter or revs per mile for this tire yet.
  10. Mike James
    142
    35
    Lincoln, NE
    Toyo tires are sold by 1010tires.com
  11. dhanson865
    851
    188
    TN, USA
    Thanks, that's useful to know one sense (I didn't know that) but unfortunatley 1010tires.com doesn't list tire diameter by size or revs per mile by size for their tires.
    I've looked at several sites that sell Toyo tires and none have specs for the tires that go any further than the bare minimum it takes to find a price.
    And for whatever reason Toyo's own web pages don't list that model tire in anything other than the press release saying it'll be the OEM tire for the Prius v.
  12. Mike James
    142
    35
    Lincoln, NE
    I am getting my winter tires soon. When I do the swap I'll measure my A20's and post.
  13. Mike James
    142
    35
    Lincoln, NE
    I measured the revs per mile on my Toyo proxes A20 at 814.8 per mile.
  14. kanedale
    kanedale New Member
    San Francisco
    Thanks for the wheel info. I just picked up my V yesterday
  15. hrududu
    hrududu New Member
    Colorado
    Can someone give me some Toyota part numbers for steel wheels that will fit a Prius v? Saw in other threads have some options and recommendations on wheel diameters and tire sizes. We have a v package Five on order and want to get some steel wheels and winter tires as we're in the Colorado mountains.
    Thanks!
  16. vloveride
    vloveride Junior Member
    Wisconsin
    Thanks Toyofixer. I picked up a set of 16x7 wheels on Tire Rack that are +40 offset for our Three for a perfect fit.
  17. Mike500
    Mike500 Senior Member
    2,593
    766
    The new Prius V uses the 5x4.5 Toyots pattern that also fits Models (Camry, Avalon, Solara). regular Prius models have the 5x100 bolt pattern
    The offset on the 16 inch wheels are 39mm. Used wheels from the late model Camrys, Avalons or Solara would be a good fit for snow or winter tires.
  18. Guill
    Guill Member
    165
    23
    Italy
    Mike,
    I'm also looking at picking up some winter tires (with wheels) for our Prius V. What tires are you looking at? Are you purchasing tires already mounted on wheels?
  19. Mike James
    142
    35
    Lincoln, NE
    Snow tires in the spring? in Texas? Whatever floats your boat I guess. I purchased Michelin X-Ice2, could not be happier. look for my thread about it for full details.
  20. anewhouse
    anewhouse Active Member
    191
    105
    CNY
    For what it's worth, rims from a Mazda6 fit the v just fine. Same bolt pattern, same offset. Hub is a little bigger (67mm) on the Mazda, but a set of hubcentric rings from Amazon took care of that.
    hope this helps!
    ozjimjam likes this.
