when it snows, the Prius needs to be jump-started
Discussion in 'Gen 2 Prius Main Forum' started by TM2647, Jan 14, 2011.
  1. TM2647
    TM2647 New Member
    Boston
    I had a 2004 Prius beforehand, and it turned out that water was leaking in through the roof of the car where the antenna was through a smallest little hole. I exchanged it for a 2008 prius this past spring (so last winter I still had the 2004 Prius, which worked great through the snow at the time living in Western Mass). Now in Eastern MA for the winter with the '08 prius, whenever it snows it needs to be jump started. I brought it into the dealer the first time and they said it was fine. I'm brining it again soon. Regardless of what they say I will probably be getting a completely different car because I refuse to play that game at 6am before work or 9pm after work. Has anyone else had this problem?
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    It sounds like your 12v battery may be week. Have it tested before starting in the morning. It should be 12.0 volts or better. H
  3. Patrick Wong
    18,200
    6,490
    I suggest that you replace the 12V battery now (and do not bother having it tested.)
  4. uart
    uart Senior Member
    4,220
    1,209
    Australia
    So why get a whole new car when just a new 12V battery will definitely fix it. :confused: That seems like just tiny bit of an overkill to me.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Replace the 12v battery!!!
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi TM...,
    When you leave the car (2nd Gen Prius), make sure you lock the car with the remote. The yellow marker lights should flash. If they do not, then you have a door ajar. This runs the interior lights contiuously, and will run down the battery. Do this a few times, and like any vehicle 12 V battery, it wont hold a charge very well.
    The most common door ajar for me was the Hatch. Make sure you really bring that hatch down firmly when you close it. The trunk light is below the tonneau cover, and is not visible from outside the car with the hatch down.
    You may also want to upgrade to a deep cycle battery. Checkout elearnaid.com for their Prius replacemetns. the Optima yellow-top batteries they sell are combination starter and deep cycle batteries. They sell a kit of parts ot adapt the Prius to the larger SAE style terminal posts on the Optima battery. This battery is also stocked at Advance Auto. But, you will need the adapter kit to use it on the Prius.
  7. bisco
    50,801
    wait a second guys, what is the correlation between snow and the battery?:confused:
  8. Patrick Wong
    18,200
    6,490
    There is a correlation between snow and cold weather.
    Snow -> Cold Weather -> Impaired functioning of weak 12V battery
  9. bisco
    50,801
    right, but doesn't it seem an odd way to put it? when it snows? when it's cold? in the winter? i would take it as only when it snows.:rolleyes:
  10. richard schumacher
    7,664
    1,042
    United States
    It's a case of coincidence or over-interpretation.
  11. uart
    uart Senior Member
    4,220
    1,209
    Australia
    That's *exactly* what I thought Richard, up until now that is. Just now I checked the OP's other posts here (there's only two of them) and in this thread in the Gen3 forum http://priuschat.com/forums/gen-iii...rst-car-in-history-in-winter.html#post1246232 he says :
    So that's a weird one.
    Hopefully the OP can provide some more details as I've never heard of this one before. The one off post nature of the OP makes it seem like perhaps this is more for the purpose of a rant than a serious attempt to solve the issue though.
  12. eldiee
    eldiee Member
    118
    17
    Iowa on Mississippi River Bluffs
    You have hit the proverbial "nail on the head"
  13. cthindi
    cthindi Member
    177
    85
    Connecticut
    There is one more reason too.
    With snow covering the ground day time temperatures would not go as high as if the snow cover was not present. Much of the energy from sun would be used up in surface melting of snow.
    While in the night , there would be more than usual radiational cooling. Nights with snow cover are supposed to be cooler, that when there is no snow cover, other variables remaining same.
    If it was my car, I would have definitely changed 12 V battery.
  14. TM2647
    TM2647 New Member
    Boston
    it's only when it snows. We've had two snowstorms in the past couple of weeks, which accumulated about a foot or more each storm. Dustings it is fine & cold weather. The other day it was as low as 9 degrees and it was fine. Just lot's of snow is where there is a problem.
  15. richard schumacher
    7,664
    1,042
    United States
    The mere presence of snow all by itself is not causing the battery to die. There's some associated factor we don't know about. For example, when it snows a foot does that mean that the car is left sitting and not started for a longer time? say, for a few days instead of the usual one day? This gives the (already damaged) battery more time to self-discharge.
    The OP needs a new battery regardless.
  16. TM2647
    TM2647 New Member
    Boston
    It's only left overnight outside as usual in my driveway. I drive it every day, at least twice a day; to and from work & the gym, errands after work, going to meet up with friends, etc etc. A snowstorm will hit, go to move the car so we can finish shoveling the driveway and it just won't respond even if I plug the fob into the slot. All the lights will go on in the dash, the horn won't work, and slowly the lights will dim on the dash. Then if I jumpstart it, it will work fine.
    My mechanics this weekend found a paper clip in the area where the hatch closes, stating that could be the problem. That the weight of the snow, causes the hatch to hit that paperclip & that drains the battery. I'm not really satisfied with that answer. I don't understand how throughout that day while the car is parked outside with all of the snow on it, that the battery doesn't die again.
  17. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    First off...... I know squat about the 2004 Prius. As others have said it's probably your battery. But, if your 2004 has a sensor on the dash to tell the car it's nighttime, as my 2010 does. Try this, during a day without snow....throw something over this sensor....see if your battery goes dead.....this could help find your problem.
    Just fishing........but sometimes that what we have to do !!
  18. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    I sort of see where you were going with this, but it doesn't quite add up. Snow on the ground reflects sunlight, which keeps the ground colder. The snow also insulates the ground, which may keep it colder or warmer, depending on initial conditions. Regardless, we aren't talking about the temperature of the ground, but only the temperature of the OP's Prius. Snow on the ground will help warm a Prius on a sunny day, as it increases the amount of gradient energy striking the car. Snow covering the Prius would have the opposite effect, although it would also serve as an insulator.
    Snow at night works mostly as an insulator. Cloud cover is one of the bigger factors, keeping heat from radiating into the sky. If you want cold, go out on a dry, clear winter night.
    Tom
  19. Optimus
    Optimus Member
    274
    25
    I just don't see anything logical about snow or snowfall itself that would cause a battery to drain. Something else is going on here. If there have only been 2 snowfalls, this isn't enough to establish a pattern.
    If we were talking about rain, then yes, there could be things caused by rain. Note that there is not a known issue with rain and starting problems on a Prius. I can think of other issues on other vehicles (particularly older vehicles), but it's not helpful to the topic at this point. But snow, especially on a parked car that has been sitting overnight, is not going to creep in somewhere and cause a battery to drain. BOTH batteries are well protected from rain/snow (assuming the car is stock, not hacked up). I would also be finding a new dealer or new mechanic at the dealer.
    A paperclip? Seriously? Maybe if it had somehow been rigged to trigger a cargo or dome light to stay on AND just coincidentally only happen to do that twice during 2 snow falls (in other words, not likely).
  20. bisco
    50,801
    doesn't make sense to me either unless the snow is being driven under the hood, melting and shorting something? either way, i agree with richard. if it's the original battery, might as well change it before it dies on you somewhere. if that isn't the problem, it was money well spent anyway. are there any gaskets along the edges of the hood where it meets the body that could be missing?
