When should I expect to start getting great mileage?
Discussion in 'Newbie Forum' started by hodgdon, Apr 1, 2008.
  1. hodgdon
    hodgdon New Member
    Lee, NH
    A couple stupid newbie questions:
    - I've barely owned my new 2008 Prius for 24 hours and I have driven it about a mere 35 miles so far, but the average gas mileage consumption has been around 31-33 MPG so far. My driving pattern has been about a 50/50 split of highway commuting and in-town driving. And I've been driving it pretty gently as well. Does it take a while for the hybrid system to break in and start getting better mileage? Or should I be concerned?
    - I've read with interest about all the Prius modifications people have made and recommend in this forum. But if you are a person whose #1 reason for buying the Prius is for maximum gas mileage efficiency, wouldn't physical modifications to the car's body such as mud flaps, bras, side panels, hood shields, etc. interfere with the car's aerodynamics and cause drag and thus decrease fuel efficiency? Or is the decrease too insignificant to worry about?
    Thanks,
    Steve
  2. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Hi Welcome to Prius chat!
    The Prius is designed to be driven like other cars. Driving it "pretty gently" may be working against you.
    Of course, any car gets better MPG if you avoid hard acceleration, abrupt stops, and not paying attention to traffic patterns. So, just drive the Prius like that... watch those stoplights/signs, ease off the accelerator a bit earlier for stops.
    Keep looking around here... there is a whole forum on fuel efficiency! :)
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I got 50 + right from the start, the first thing I did when I left the dealership was reset the consumption screen. To save you some time here are the best tips that require no modification.
    1. Short trips kill MPG also don't leave the car in Ready mode while parked for more then 5 minutes. (if running errands go the furthest place first)
    2. Warming up the car in the morning also bad for mileage
    3. Don't use the heater or A/C for the first 5 minutes
    4. Put some air in those tires. (even just 38 PSI will show quite an increase, and is quite a comfortable ride still)
    5. Learn how to at least glide through city traffic (no arrows through town and down hills) (avoid use of Yellow arrows)
    6. Accelerate moderately (try to keep your instant MPG at least half your speed)
    7. If at highway speed and going down a hill instead of letting off the pedal (Blue arrows / regen) feather the pedal down just a bit and let it glide down with the hill using the battery (yellow arrows), I think that is frequently called warp stealth.
    I hope this helps
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    To answer your last question, physical modification will not help; some won't hurt, some will, but the Prius is pretty aerodynamic as it comes from the factory. There are a few mileage nuts who have added fairings, spats, and related aerodynamic accessories to some minor gain, but it's mostly a hobby.
    Tom
  5. patsparks
    10,664
    567
    Adelaide South Australia
    I think before you get too disapointed you could wait until you put 2 gallons of petrol through it, maybe even 3!!
  6. Zhe Wiz
    Zhe Wiz Member
    128
    Ithaca, NY
    Yeah, and wait for the warm weather. Here in NY temps went all the way to mid 60's today and my MPGs were in the low to mid 50's for the day. Incredible how much easier it is to get good mileage when the weather warms up! And I loved it at 45 MPGs!
    Jack
  7. hodgdon
    hodgdon New Member
    Lee, NH
    Thanks for everyone's quick response. I reset the consumption as suggested and, sure enough, I averaged 53 mpg on my commute into work today.
    And thanks for the other tips, Morpheusx. I don't understand all them yet (e.g. yellow and blue arrows), but I look forward to learning and trying out your driving strategies.
    - Steve
  8. richard schumacher
    7,664
    1,042
    United States
    Uh, why not? The engine is going to run anyway to warm up both itself and the catalytic converter; increasing the load on it will warm it up faster.
  9. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    Would you please explain a scientific theory about "try to keep your instant MPG at least half your speed" part?
    Thank you,
    Ken@Japan
  10. morpheusx
    1,555
    81
    Akron, OH
    only while accellerating (most of the Can View guys say that it typically keeps the engine in the most efficient RPM range)
  11. morpheusx
    1,555
    81
    Akron, OH
    Just try it for yourself and tell me you didn't notice a difference (from a cold start)
  12. limetime13
    limetime13 Junior Member
    86
    Indianapolis
    I found it (and still do) VERY helpful to have the MFD on the "wheels and arrows" screen - maybe called Energy? It tells you when the car is using the ICE or the motor or both or nothing at all......you can also keep an eye on the iMPG while you are accelerating and get an idea of just how hard to push the pedal.
    Keep nosing around the PC website - lots of terrific info here (one of which is how to disable that annoying backup beep)
    Welcome and have fun driving ;)
  13. dacarls
    dacarls New Member
    Gainesville FL USA
    After 6 months, I think the mph/mpg crossover is about 57 mph: steady speed at 56 mph gets more than 57 mpg, faster than 57 mph gets less than 57 mpg.
    Comments?
  14. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    I would think that would depend on terrain and weather.
  15. la cucaracha
    la cucaracha New Member
    60
    Austin
    Why avoid the use of Yellow arrows?
    Thanks,
    lacooka
  16. richard schumacher
    7,664
    1,042
    United States
    They indicate the flow of energy into and out of the traction (big) battery. It may seem like a paradox but you actually want to use this battery as little as possible. There are unavoidable inefficiencies (energy lost to heat) during energy conversions; charging and discharging a battery is especially poor.
    If I may be so bold as to attempt to summarize the excellent advice of many experienced drivers:
    The principles of good fuel economy are
    - Accelerate briskly (this uses the engine in its most efficient range)
    - Gliding (no arrows into or out of the battery on the "Energy" display) is better than coasting
    - Coasting is better than braking
    - Braking is better than coming to a complete stop.
    Applying the principles is the trick :_> Ideally one would accelerate to some maximum speed and then glide and coast to a stop at one's destination. Obviously this is often impossible.
    It's also important to not put one's self or others in danger by staring at the displays or go crazy trying to maximize fuel economy. Your Prius is probably using half or less of the fuel of your previous vehicle regardless, and life is short.
  17. richard schumacher
    7,664
    1,042
    United States
    Do you mean overall MPGs, or just for that initial time? Running the A/C will reduce instantaneous MPGs, but then it also warms up the engine faster and so decreases the length of time that the engine runs sub-optimally. The net MPG reduction should be small, and it should reduce net emissions.
