When traction battery depletes....
Discussion in 'Gen 2 Prius Technical Discussion' started by abq sfr, May 4, 2007.
  1. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    I attended a Celtic Woman concert this week (FANTASTIC!) however I parked in the adjacent underground parking garage (whatta nightmare). There were only two ticket booths to pay for parking, it took me an hour of inching forward before I got out of there at 11 pm. My traction battery went to the lowest level and stayed there, which is I guess 40% from what I've learned here. Every time I would move forward even a few feet, the ICE would fire up, then shut off when I stopped. The ICE would also start about every 10 minutes I guess and run a couple minutes, to keep the battery from dropping below 40%, but I don't think it ever gained a single bar. Also, the AC compressor would not work, and it got hot in the car. I was kinda steaming from being mad at myself for parking in there, so it got really uncomfortable. Shouldn't the ICE keep the traction battery charged to the point where the AC compressor would function well? Does the AC output depend greatly on traction battery charge?? I think a "regular" car would blow air a lot colder than the Prius did under these conditions. My first disappointment with this car, when it gets 100 degrees here this summer and I'm stuck in traffic, I hope I don't melt down!!
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The AC compressor runs off of the high voltage system, so it does require the traction battery. That said, there is no reason it should fail to run as long as there is gas in the tank and the Prius is turned on. The Prius should run the ICE as needed to maintain charge, and the AC should work fine. Check to make sure your AC settings are correct; if they are, you might need to see your service department.
    Tom
  3. daniel
    14,487
    1,519
    Spokane, WA
    I agree with qbee: The behavior of your engine was normal. It is annoying, but that's the most efficient way to operate. However, your A/C should have functioned, because 40% battery SOC is plenty to operate it, and the engine will provide the necessary charge. Either you didn't have the A/C set properly, or there is a defect.
  4. Tideland Prius
    16,403
    Hmm... the engine cycling is normal but usually when it drops to one bar, it stays on and charge until 3 bars. I haven't had much experience with low battery (for the sake of mileage) but the few times that I dropped to two, it managed to get to 3 bars without idling (i.e. charge while I'm creeping along).
  5. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    Drove your Prius to a Celtic woman concert??? That's just too perfect! :p
    Seriously though, somethings astray here. Toward the end of last summer, I was on a long drive and got tired enough that I stopped in a rest area for a snooze. My car is black, and it was a hot day on the gulf coast, so I wasn't about to just shut everything off. With the car in an initially high state of charge initially (from the decel from highway speed), I just put the car in Park, leaned the seat back, and went to sleep. Though I was asleep, I would est that it took ~15 minutes, maybe a bit more for the AC to eat up the charge in the traction battery. At that point, the ICE would come on, run for a minute or so, go off, and then come on again in several minutes later. At no point did the AC falter. Although you were doing the bumper-to-bumper creep thing, and I was stationary, the cars should have exhibited similar behavior.
    The general pattern for situations in which the car has substantial HV draw, but not enough regen opportunity to keep up, is for the system to run the traction battery down to the minimum acceptable level, and then start feeding in ICE as necessary to keep the charge up in the acceptable range.
  6. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I was stuck in traffic yesterday for an hour in 91° LA. The battery went down to the last bar, and the engine cycled on and off as needed, but the AC never stopped, or missed a beat. It doesn't happen that often, but it seems to OK for my car.
  7. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(subarutoo @ May 8 2007, 01:25 PM) [snapback]437678[/snapback]</div>
    Thanks for the input everyone... maybe I just had the AC wrong, its so easy to get it wrong in this car, seems like I'm always moving the temp control from max to min and vice versa... and sometimes find the heat on when I think only the blower is on! Climate control controls might be the thing I like the least in my Prius. It should be really simple to go from outside air vent only, AC, Heater, without having to push 3 buttons and a temp up/down button 10 times, especially when outside air only gets you the best mpg! Subarutoo, did your ICE come on every time you inched forward and then shut off when you were stopped? The ICE was not shutting off cleanly either, it seemed to stutter when it shut off. It literally took me 30 minutes to go 100 feet.
  8. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(abq sfr @ May 8 2007, 12:36 PM) [snapback]437687[/snapback]</div>
    That is normal when the HV battery is low.
    It will get smoother as your car gets more miles on the odometer.
  9. qbee42
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(abq sfr @ May 8 2007, 03:36 PM) [snapback]437687[/snapback]</div>
    Leave it on AC Auto and adjust only the temperature setting. The Prius does a good job taking care of the details.
    Tom
  10. wyounger
    wyounger New Member
    69
    Atlanta, GA USA
    Agreed, leave it on auto. They put a great deal of thought and energy into that system and it makes very good decisions.
    I would add, though, that there's no need to adjust the temperature setting so much. You're setting a "desired cabin temp". If it's really hot or really cold in the car the system will work on getting to your setpoint as fast as it can; exaggerating to those temperature extremes won't make it get there any faster. You can actually see that by going into the Climate screen. If the system is in Auto and the fan's on it's already giving you all it's got.
    I've had mine enough to go through hot and cold weather and thus far have not felt any need to override the decisions it was making, and very rarely ever adjust the temperature setting. During the winter I left it on 73 most of the time, and now that it's gotten warm I'm generally keeping it on 71.
