where are the beepers
Discussion in 'Gen 3 Prius Accessories and Modifications' started by walter592, Mar 18, 2010.
  1. walter592
    walter592 Junior Member
    36
    OK, i got the dealer to disable the reverse and seltbelt beeps. All the other beeps are driving me crazy. I'm fed up... does anyone know where they are located (there's one external and one in the car. I would like to either remove them or cover them with something to lower the volume. My neighbour will thank you (he says the beep when locking my doors wakes him up at night)
    thanks
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I have an '04 which is the same model as yours. I hate that I can not lock my car without the beeps. I have always muted the beeps in other cars. I muted my wife's car. The headlights flash and that's it.
    I don't know where they are located.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Well this is for a GenII, but the technical circuit diagrams shows the inside "Buzzer" located inside the combination meter. The way it reads, the internal MCU inside the combination meter actually determines if the buzzer should sound or not. So it would seem your only options would be to disassemble the meter and physically desolder the buzzer, spoof signals into the combination meter so it never thinks it has a reason to sound the alarms (this would also render most of your display useless), or just live with it...
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Where have all the beepers gone?
    Long time asking.
    Long time ago.
    The answer, my friend, is beepin' in your drive,
    the answer is beepin' in your drive.
  5. DavidA
    2,339
    1,817
    Chicago western burbs
    There's a rocker button on each front door that locks the car before you close the doors. I believe it might be a quieter option.
  6. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I don't know where the beeper is, but it is a configurable option to have the lock/unlock accompanied by beeping. It's the same sort of option that requires the dealer computer system to set, like changing the reverse from continual beeping to once. I had the dealer make both those changes as quickly as I could when I got my 2010, I believe cars should be seen and not heard.^_^
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    As Walterm said they can be changed, there are volume settings and they can be turned completely off. Owner's manual page 587. Unfortunately you will have to have a dealer do it for you.
    Adrian Black and RobH have found the codes to turn the backup beeper and seatbelt beepers on and off using a ScanGauge and these other beepers could probably be done the same way but we don't have the codes for them, yet.
    ScanGauge work is discussed at length on this thread http://priuschat.com/forums/gen-iii...cussion/64406-scangaugeii-work-2010-a-20.html
  8. TonyPSchaefer
    14,816
    2,499
    66
    This is what I do most of the time. But when I get to work, I close the driver's door, open the back door, grab my backpack, close the back door, and hit the lock button. It's just easier than opening the driver's door and hitting the rocker switch. Also when pulling something out of the hatch.
    But when I'm getting out to go to the store, for example, I hit the rocker switch BECAUSE it's the quieter option.
  9. Politburo
    Politburo Active Member
    971
    208
    Your neighbor sounds like a bucket of fun. A single beep wakes him up? How does he get any sleep?
  10. qbee42
    18,058
    3,076
    Northern Michigan
    The lock beeper on my 2006 is very quiet. It's not like the horn honk used with many cars.
    Tom
  11. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    My SAAB honks the horn twice. I don't even notice the Prius beeps.
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I find my 2006 prius quieter than our 2007 lexus RX. It is the same "chrip" sound, but the lexus is much louder. Maybe bigger car, bigger beep?! :)
  13. RobH
    RobH Senior Member
    2,369
    984
    70
    Sunnyvale, California
    If the beeps are a problem, just use the mechanical key.
