where is interior air intake for recirculate
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by etyler88, Dec 2, 2005.
  1. etyler88
    etyler88 etyler88
    450
    Dover, DE
    Anybody know where the interior/cabin air intake is? I want to spray an air freshener into it. I thought it was the vent by the rear seat but that is a battery vent. I did find the exterior intake by the wiper.
    Thanks for any help.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Can't you just spray the interior filter behind the lower glove box?
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :) Hi etyler88
    The Outside Air Intake is located just beneath the passenger side windshield wiper. You will see a black plastic "grill" there.
    You might get better results by cleaning, spraying or changing the cabin air filter located behind the lower glove box. It's easy to access. Directions can be found (including photos) on John's web site:
    http://john1701a.com/
    You might also search on "filter" or "smell" - "musty" etc.
  4. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    I'm pretty sure the inside intake is behind the lower glove box, just below (or above) inside air filter. If you remove the lower glove box and then select recirculate you will see it open up.
  5. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    That does not answer his question. He knows where the outside air intake is located; he is looking for the recirculating air intake.
