Which Emblems have holes?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by sprfrkr, Sep 10, 2008.
  1. sprfrkr
    sprfrkr New Member
    I found this post where the user removed the emblems of his car from the rear: (new user not allowed to link to the older thread apparently)
    I asked my car guy to remove my emblems as a personal preference and he stated they had guide holes behind them. Perhaps it was just the side "hybrid" logos that have the guide holes? Can anyone confirm which emblems do have guide holes behind them and which do not? I am not going to remove the front/rear Toyota symbol.
  2. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    sprfrkr,
    Welcome to PriusChat.
    You got it right; only the "Circle-T" badges front and rear, and the
    HybridSD badges on the front fenders have holes.
    Debadging is very easy. Use the search function with the term
    "debadging" for a few different methods. (It's to the right on the blue
    bar near the top of the page.) Most everyone who's attempted
    it has been successful -- including me.
    Save your $$$ for a ScanGauge, BT Chassis Brace, Sharkfin, whatever.
    Goodluck.
  3. sprfrkr
    sprfrkr New Member
    Thank you kindly. I bought two synergy drive badges and one of the hybrid badges. I was going to swap the two hybrid side badges for the synergy drive ones and only have one hybrid badge in teh back, but that looks to be a no go now since the guide holes are too far apart on the hybrid ones. No worries.
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Hey, all is not lost! Dogged Perseverence is the creed of modders!
    The HybridSD badges have pins that go in the holes in the fenders. But
    the badges are plastic, so the pins can be cut/snipped off and then
    trimmed/sanded smooth on the back. Even in their original position, the
    badges are held securely in place only by the 3M super-sticky mounting
    tape. With the pins removed, you can mount them where ever you please.
  5. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    has anyone debadged the circle t? none of the pictures i have seen yet show it removed. i would like to remove mine for waxing
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    sprfrkr,
    I failed to pick up on an subtle point in your last post.
    The holes under the HybridSD badges on the fenders are not at the ends of
    the badge. The Hybrid Synergy Drive badge, like on the lift gate, can be
    used to cover them.
    FWIW, the line of the HybridSD badge is parallel to, but not the same
    as the line through the lower edge of the door handles. The holes in the
    fenders, at least on my 2008, are about 1/8 inch in diameter. Horizontally
    the centers of the two holes are 2-11/16 inches apart. The two holes are not
    in a line relative to the botom edge of the badge. For the driver's side, the
    forward most hole is behind the connetor at the botom of the B and R
    letters. The after hole is on the D, just below a line extending the upper
    edge of the HYBRID lettering. The center of the aft hole is 1/2 inch above
    the forward hole. I haven't looked under the passenger side badge, so I don't
    yet know if the holes there have the same forward-aft orientation.
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    As to removing the Circle-T badges, front and rear, Hobbit has a cautionary
    tale here:
    Prius debadging attempt
    For the full gamut of Hobbit's immense contributions to the understanding of the
    HSD, and practical, real world applications go here:
    http://techno-fandom.org/~hobbit/
