Which OBD Bluetooth scanner to buy?
Discussion in 'OBDII Android App' started by Nakamoto, Sep 19, 2013.
  1. Nakamoto
    Nakamoto Junior Member
    69
    Melbourne
    Greetings!
    I'm on the market for an OBD scanner bluetooth adapter. My online research summarised - there are 3 main types; namely - ELM327-based adapters , ELM327 clones and STN1110 based OBD scanners.
    It now come down to:
    1. Scantool - OBDLINK MX (STN1110) -$150
    2. STN1170 ODB Bluetooth Adapter - $110
    3. ODB-Pros Scantool Bluetooth (Genuine ELM327 ) - $160
    I'm planning to use pair it with my nook hd. I'd appreciate further inputs from you guys! Thanks!
    Galaxy Nexus ? 2
  2. vskid3
    vskid3 Active Member
    773
    228
    I would search for "ELM327" on Amazon and pick the cheapest one with good reviews. I bought mine for under $15 and its worked fine.
  3. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Cheap clone scanners will drain your battery if you leave them plugged in. Scanners that have the STN chips have a sleep mode. Be careful with your app settings. Torque has a setting for the OBDlink MX that must be set to allow it to sleep.
  4. Nakamoto
    69
    Melbourne
    I don't have other OBD bluetooth adapter for comparison, but I must say this device is well worth every penny spent! It is well made and work out of the box with minimal fuss - took me mere seconds to get it paired with my phone and tablet. The power-save sleep mode works like a charm and PID read speed is instantaneous on torque android app.
  5. unterhausen
    unterhausen Junior Member
    64
    State College, PA
    I don't see which adapter you are talking about.
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I bought a cheep Amazon ELM327 it didn't work with my tablet. I thought it was the Tablet's fault until I replaced my phone with Android version. Then I found it did not see the bluetooth connection at all. I guess I will need to try another one. $20 bucks wasted!
  7. neez
    neez Member
    194
    37
    I bought this one on amazon and it works with my nexus 7 tablet and LG Optimus G android phone. It works very well, i just wish it would turn off with the car so i could leave it plugged in all the time. But for $15(i'm a prime member, well worth it), it's a great diagnostic tool.
    XPCman, perhaps you bought a defective one that will never work, ever.
  8. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Do you drive your car daily? Then you shouldn't worry about the ELM327 adapter draining the aux battery. I leave my adapter in all the time and I haven't noticed any change since I installed it. YMMV.
  9. Maxroach
    Maxroach New Member
    London
    stay away from wifi obd scanners - blocks your mobile signal - not useful if someone trying to get hold of you!!
