Why are my tail lights on?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PA, Oct 10, 2006.
  1. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    I have noticed a couple times (when I have left my headlights switched 'on') that when I return to the car the tail lights, or more specifically the bulb in the red cube in the lowest of the 3 light positions in the tail light assembly (are you still there?), is on. Of course, the obvious solution is to just turn off my headlights, but I thought the auto-off feature was supposed to turn off all the lights when I turn off the car and open the door. I don't know if the lights in question have been on the whole time, or whether it has something to do with the SKS. The bulbs are definitely on, and not just reflecting sunlight, because I can see the filament glowing (and it goes out when I turn the lights off).
    I tried searching for this topic but wasn't really sure what to be searching for! Any assistance would be appreciated. Thanks.
  2. silentak1
    silentak1 Since 2005
    893
    28
    LA
    The same happens with me when I do this:
    1. Turn off the car
    2. Turn off and on the lights
    3. Lock the car
    Yes it's quite stupid of me to do such thing, but they stay on...
    Maybe i'm crazy but it has also occured to me that once or twice i shut my car off, locked the car, and the lights remained on either way. No explanation for this one...
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    the auto off feature only works in a fairly specific situation: You have the lights on, turn off the car, and then open the drivers door. Doing any of this in another order will cause the lights to stay on.
    So, for example, if you turn the lights on after turning off the car, they'll stay on. if you open the drivers door before turning off the car, they'll stay on.
    Make sure you're "obeying the rules" and it should be fine.
  4. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    B) My "Old habits remain strong."
    So many years, I always turned the headlights OFF, then turned the ignition OFF. Accordingly, I don't depend on the Toyota "auto off" feature. I am grateful for it, though, since my wife has learned (in her Camry) to depend on the "auto off" feature so when she drives the Prius, she (as I) stays with her old habits and leaves the headlight switch ON.
  5. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    How can you tell that you're getting old?
    --I'm so old that, even though I have a car that turns off its headlights automatically, I still stand around and wait for them to turn off...then walk away in the dark
    Now, this has me thinking...
    --I'm so old that I have a box full of dictaphone belts in my garage.
    --I'm so old that I can remember why they used to call the TV remote a 'clicker' and when cc'ing someone actually involved carbon paper.
    --I'm so old that I still call CD's "albums."
    --I'm so old that I pine for the taste of Space Food Sticks and Tang
    --I'm so old that I can remember when being a stripper meant that you worked in the printing trade, cutting rubylith.
    ...now that's old!
    [smile]
  6. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 11 2006, 09:22 AM) [snapback]331081[/snapback]</div>
    Thanks. On those two occasions when the lights were on, I must have done things in a different order as you indicate. It was sometime around the middle of the day so I'm assuming the headlights were on but I didn't notice them (but I saw the tail light as I approached from behind the car). I didn't realize I had "overridden" the auto-off so that's why I couldn't figure out why they were on (and it happened so infrequently).
    <div class='quotetop'>QUOTE(Charles Suitt @ Oct 11 2006, 02:55 PM) [snapback]331282[/snapback]</div>
    Yes, I always turn off my lights, too, except for those few times. Okay, ALMOST always. Just like I almost remembered to turn them off today.
