Why does the car do this?
Discussion in 'Gen 2 Prius Main Forum' started by Sheepdog, Apr 3, 2008.
  1. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    Not all of the time of course, but sometimes; and I honestly don't know why, sometimes when I get out and push the button on the remote key to lock the door- it doesnt do it!
    I push it and nothing happens. I push it harder. I push it several times then it locks!
    Why? Me dont know!
  2. kimgh
    kimgh Member
    297
    San Jose, CA
    Sometimes happens on to me on the first try, but usually the second try is successful.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Are you the only driver, or is another key fob involved? Wireless key fobs use a rolling code system, where the code changes for every push. If your fob issues a code that is within a target number of previous codes, everything works as expected. If your fob gets too far out of sync, the car and fob have to resynchronize. Engineers struggled over the best way to do this, and what we came up with is multiple pushes. When a button doesn't work, the normal behavior for most people is to try it again. This action is used to force resynchronization.
    Here is an example: Say your wife drives the car for a few days. Each time she uses her fob the code advances, so when you get the car back your fob issues an out of date code. If it is close, the car will use it. If not, nothing happens. What do you do? You push the fob button again, which advances your code to the next one. It's still out of date, but now the car knows it needs to resynchronize, since you have issued two good but out of date codes. The fob and car go through a little dance and all is good after that.
    What causes fobs to go out of sync? Anything that advances the fob or car code without doing it for both. Two drivers can cause this, or having false triggers of your fob. Keeping your fob in your pocket with a cell phone can cause the fob to falsely respond, each time advancing its code. This wears down the battery in the fob and also wrecks the synchronization.
    Of course, simple radio interference can cause your fob to not work. Sometimes this happens on military bases or other locations with strong transmitters, or having your cell phone close the the fob.
    Tom
  4. darelldd
    6,059
    389
    Northern CA
    If you keep the fob in your pocket, try removing your foil underwear, and try again.
    My guess is that the fob is not being "seen." Try standing closer to the car, or holding the fob in your hand. I'll bet it works the first time then.
  5. Sheepdog
    1,125
    Sanford FLorida
    thanks qbee. My wife has my extra fob in her purse and I have her extra fob in the hidden storage under the cup holders. Maybe when she walks up to the car it advances the code? it unlocks without her touching it just like mine. Does using the interior button to lock unlock or the button on the door handle interfere with the fob codes? strange.
    Funny thing is-her prius never does it.
    Foil underwear! harhar! Darell you so funny! Number 1 GI!
  6. SparrowHawk60
    SparrowHawk60 Happy to be green!
    411
    Town of Newburgh, NY, U.S.of A.
    Funny, how we push the buttons harder on the remotes when they don't seem to work. (Yeah, I've done it too.)
  7. qbee42
    18,058
    3,079
    Northern Michigan
    A few random actuations shouldn't desynchronize the system. It could be where you carry your fob, or it could be the battery in the fob. Try trading yours for the other fob.
    Tom
  8. hill
    8,810
    Yep, foil shorts block the r.f.
    Also, try keeping your cel phone farther away ... they've been known to block the FOB signal.
  9. lesturner
    lesturner Taming the Dragon - Tennessee
    75
    Bremen, IN, USA
    I cannot lock my car using the buttons on the doors when my wifes fob is in the car. Once she takes it with her, it locks fine.
    Is there any chance the remote buttons react differently if there is a fob in the car as well?
    I would try and remove the 'stored fob' and see if it works properly. I hardly ever use the buttons on the remote... So just a thought...
  10. richard schumacher
    7,664
    1,046
    United States
    The car isn't supposed to lock if it detects a fob inside the cabin. It's a feature.
  11. Sarge
    Sarge Senior Member
    1,325
    784
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Ditto what Richard said. In fact, you should hear a long BEEEEEP if there is a fob in the car. This is the 'smart' part of the smart key.:p
    I have noticed on occasion if I have my fob in my pocket with my PocketPC, it sometime won't recognize it as well. Ditto for downtown, where on occasion it won't recognize it. (In fact, I know of a parking lot where I was almost forced to key-open my old car with alarms a-blazing since there was so much interference it wouldn't recognize the signal... had to hold the fob right on the windshield for it to work... happened numerous times, always in the same lot, worked fine anywhere else. But I digress...);)
  12. Sheepdog
    1,125
    Sanford FLorida
    We have 2 Prii Richard. I keep her spare key and she has mine. Her Prius key fob shouldnt matter in my car. Just like my spare shouldnt matter in hers.
    If the key fob battery is serviceable, how would I do it? or just take it back to the dealer?
    You know what would happen- they would try the fob and it would work perfectly!:laser::eek:
  13. richard schumacher
    7,664
    1,046
    United States
    Oh. My bad.
    Assuming that there's no cell phone or mass of metal (coins, other keys, etc.) in your pocket or that you are holding the fob when the failure happens, I'd bet on a dying fob battery. As I recall you get access to the screw that opens the fob's battery compartment by removing the mechanical key.
  14. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    I wonder if that is true? Obviously an SKS fob with a different code won't start/open your car, but does that mean they don't keep talking trying to sort things out? Hopefully not, but its not outside the realm of possibility. Might be worth trying taking her key out for a few days, see if it helps.
    Rob
  15. Sheepdog
    1,125
    Sanford FLorida
    yes I think I shall do just that.
  16. jsnschmasn
    jsnschmasn New Member
    17
    St. Louis, MO USA
    It's not just you. Mine does it, too. I don't have another FOB anywhere near it. It just freaks out for 10-20 seconds every once in a while right after shutdown and won't let me lock it. I thought it might have to do with that noise it makes right after it shuts off but I'm not sure. What is happening when the noise sounds?
