will 15x7 rims work with factory tires?
Discussion in 'Prius c Accessories and Modifications' started by Lunercrab, Apr 5, 2012.
  1. Lunercrab
    Lunercrab New Member
    26
    North Eastern PA
    Discount tire is showing rims for the Prius c now. I saw some I like but they are 15x7. Will that size work with the factory tires that come.on the c? I don't wanna get new tires yet. Thanks
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    You have to find out what tires they are and look up their specs on TireRack or something. There is a spec for maximum width.
  3. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    5"-6" is the recommended wheel width for the 175/65/15 tire. A 7" wide wheel may work with thatsizetire but it would produce an awful stretched look and some tire shops may not install it. IMO find a different wheel or buy a new tire. The c doesn't really need a 7" wide wheel unless you are going for the best handling and don't mind a mpg hit.
  4. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    Even Tire Rack is saying the 175 tire is the recommended tire on a 15x7 rim. I do not know if I believe that either, but I'm having the stock 175 mounted on some 15x6.5 rims as I type and I'll take some pics as to how the tire/wheel looks once I get them back from the shop.
  5. Mike500
    Mike500 Senior Member
    2,593
    766
    Basically, measure the width of the tread on your curren tires. if they are less than 7 inches, you'll be riding on the corner of the sidewalls.
    The tires are not designed for that and will wear out quickly. Either get the correct wheels fo your current tires or the correct wheels and tires.
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    FWIW: "Slammed" or "Hellaflush" wheels
    :eek:
  7. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Tyrestretch.com is the site I use.
    Here's a 175/55/15 on a 15x7. Little stretch but nothing offensive. I would just go to a 185 or 195 if possible just to be safe.
  8. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    If you look at the specs on a 175/65/15 tire is reads 5"-6" rim. Try looking up the AVID Ascend or the Ecopia EP422.
  9. Lunercrab
    26
    North Eastern PA
  10. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    I'm already looking at the EP422 in 185/60 if the 175s don't work out.
  11. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    175/65/15 = revs/mile 866
    185/60/15 = revs/mile 873-880
    There is a bit of difference in revs per mile between the two so your speedometer may read even higher than it already does (1-2mph too fast) and your odometer will likely be off but since tires wear down with use these figures are never exact. Just know that you may have an artificially high mpg number as a consequence of shorter tires. At least they are more likely to fit. :D
  12. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    I've resigned myself over the years to accept tire height difference of a few tenths of an inch and not worry about it anymore. Sure, it will affect mpg calculations, but I'm not that anal that it being off by a few mph or mpgs matters to me now. If it's close and acceptable, I'm happy. I do compensate for any delta by setting the cruise so I know the real speed I'm traveling. I use the speed signs that shoot and displays your speed to calibrate my speedo error after any tire changes.
  13. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Then you are in good shape. :) Don't sweat the small stuff right?
  14. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    I sure hope so. Hopefully, what I consider small stuff (175 tire on a 6.5 rim) will not grow to be bigger problems in the future. If they do become problems, you can be sure that I will report back on the forum and admit a mistake.
