Will adding aftermarket equipment void the warranty?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PriusRoadWarrior, Dec 5, 2009.
  1. PriusRoadWarrior
    76
    16
    Wisconsin
    I want to add a remote starter from a local quality installer to my 2010 Prius. Will doing so void any part of my warranty? Toyota says the kit alone is $500.00 plus installation. A lifetime warrantied local installation is $399.00. If I go to Toyota, I can imagine the total cost easily being in the $700 to $800 dollar range. Has anyone checked out after market additions and how they affect your warranty? Thanks ahead of time.
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Toyota cannot be responsible for changes made to their design by others. So don't expect a warranty on any changed parts. But a remote starter is not going to make the rear seatbelts to rip, parts not effected by the aftermarket enhancement are still covered. I would ask the installer what all he will be changing. (Electrical System, Dash?, relocating parts under hood?. etc.) Does his 'lifetime warrantied local installation' cover the Toyota parts he impacts, or just the parts in his kit?
  3. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Here's my 2 cents....:)
    I would barter hard with my dealer to see if they can install the Factory Remote Start (designed for the Prius), to get their cost down some from retail.
    The Factory Remote Start, utilizes your existing Fob, no need to carry another brand remote with your Fob. Plus it would NOT void any warranty when installed by Toyota.
    The hundred dollars or so saved may not be worth it in the long haul.
    The Wisconsin Winters, like Buffalo, would make it a worthwhile investment, and piece of mind is important with the complexity of the electronics in the Prius.
    Nothing worse than having a later problem from something installed incorrectly, to have the dealer say "Oh I see you added an aftermarket Remote Start" that could be your issue.
    Toyota could say that an issue was caused by the NON TOYOTA REMOTE START, and the diagnostic fee's (maybe although not related) would circumvent the initial savings. ;)
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The wiring system on a Prius is complex. I would think long and hard about a non-factory remote starter. It may work fine, but it could be a ticket to a lot of expense and frustration. At the very least, find out how many Gen III Prius remote starters the installer has done, and ask to talk to some of them.
    Tom
  5. PriusRoadWarrior
    76
    16
    Wisconsin
    I gues you have a valid point there, I will see if I can get them to lower their cost.
