Will park at LAX for 13 days. Dead battery for sure?
Discussion in 'Gen 3 Prius Main Forum' started by Bruno_S, Sep 20, 2009.
  1. Bruno_S
    Bruno_S New Member
    130
    68
    On Tuesday I am going to Paris for 12 days and will leave the Gen III in a LAX parking structure (covered). Will I be able to jump start like any other car or are there certain precautions I should take. I am assuming the 12 Volt battery will die after 13 days. The parking I will use has free jump starts :)
  2. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    My guess is that your 12 volt battery will live for 13 days in LA temperatures.
    In any event, as to jump starting the Prius, it's different from other cars in that you don't attach a jumper clamp directly to the Prius' 12 volt battery. Instead, inside the main fusebox under the hood there's a positive (red) jump terminal. It's tiny so you may have a little trouble attaching a jumper clamp to it, but it's doable.
    See pages 643 - 645 of the Owner's Manual for complete instructions and illustrations for jump starting your Prius.
  3. derkraut
    derkraut Member
    299
    28
    SAN
    Check your owner's manual for instructions on how to disable your smart key (push-button under the dash by the steering column). I've had my 2006 parked for 25 days with no problem starting, providing you disable the smart-key function.
  4. Bruno_S
    Bruno_S New Member
    130
    68
    My previous car, a Volvo S60, had the battery in the trunk and two terminals next to the engine like all normal cars. The large transversely mounted I-5 didn't leave room for the battery up front. Will read the owners manual and try my luck with the LA weather.
  5. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    Not the same in the 2010...
  6. Boo
    5,051
    488
    97
    Flushing, NY
    That's true. But it stinks. Instead of continuing with the Gen II's easy button that allows the owner to deactivate and activate the SKS at will, Toyota tells the 2010 owner in the Owner's Manual to see your dealer. How inconvenient is that? It'd be easier for the 2010 owner to crawl into the back and disconnect the battery.
  7. bluemonday
    bluemonday New Member
    151
    26
    St. Louis
    This was posted in this forum and supposedly works. I'll be trying it later this week...
    4 people like this.
  8. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    WOW what a PIA. This is another reason I'm glad I just hanged on to my 08.
  9. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Consider buying a jumper box just for peace of mind. I doubt your battery will die in that 13 days, but it would suck to get home, tired and all, and have to hunt down someone to jump you.
    The jumper box I have has an air pump built into it (it's what gets all the use actually), so it's useful for keeping those tires juiced up.
  10. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    This does stink. How un-user friendly is that? The Prius should be designed to be idle for a couple weeks with no worry. And, if it's due to the Smartkey drain -c'mon... there should be a simple disable function for the driver. How simple could it be - I see the other post regarding programming girations --- who designed THAT - Microsoft? My car is in the airport parking lot right now for 10 days...better not have an issue.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The Prius *is* designed to sit for a couple of weeks without trouble. As for the SKS disable, it is now automatic. Actually it's been automatic for awhile, but for 2010 Toyota shortened the turn-off interval. There is no routine reason to ever go through the programming steps to turn off SKS. SKS turn off is provided for those who fear EMF issues from the SKS radio beacon (pacemaker, tinfoil hat, etc.)
    Two weeks shouldn't be an issue. The problem is that the Prius has a small battery and a lot of electronics. The battery will not survive long if lights are left on or anything else of this nature. Enough PC members have killed batteries to make all of us paranoid. Even so, two weeks with a new Prius is a non-issue.
    Evan makes an excellent suggestion: get a jumper box and air pump. It's cheap insurance for anyone that parks their car away from home.
    Tom
    Dancing Badger likes this.
  12. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Can you let us know what unit you have as I have been looking for something similar and wondered if you had a reccomendation on brand/model that has served you well. Thanks!
  13. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Great question for my dealer at the get together on Wednesday evening. :)
    Then there is Amazon.com you can get a Battery Disconect switch for $13.25
  14. DeanFL
    1,015
    355
    Tom,
    Thanks so much. Great info and reminds me I saw this a couple months ago here; possibly from you. Didn't make sense that Toyota would allow an engineering hole as that. So bottom line if the '10 Prius automatically disables SKS at some time, use the mechanical key for entry and all's the same from there.
  15. qbee42
    18,058
    3,076
    Northern Michigan
    I don't recall the details for the 2010, but I believe it's easier than that. I think grabbing the door handle reactivates the SKS, so the car will open as expected, only it takes a split second longer. Many remote systems work like this, since the natural human reaction is to try a second time when something doesn't work as expected.
    Tom
  16. paprius4030
    2,077
    296
    York,Pa.
    Ok I take back my PIA remark......just when I was feeling better about not being able to get a 2010 LOL...:Cry:
  17. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Let it surprise you, but be sure to have a AAA card handy just in case.
  18. efusco
    19,891
    1,194
    Nixa, MO
    This is the one I have, or something very similar. I' pretty sure I picked mine up at a Sam's club for about $50 or so.
    http://www.amazon.com/Black-Decker-VEC012CBD-Starter-Inflator/dp/B000EJV5N8
  19. sshaw10
    sshaw10 Member
    103
    West Los Angeles
    You can't leave a Prius for two weeks without the battery draining? Something doesn't sound correct. If you disconnect the battery for an extended period of time won't that reset all the computers and stored information or is that written to some kind of memory. It screws up some cars to disconnect the battery for extended periods of time.
  20. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    If I remember correctly from Hobbit's write up on replacing the 12V battery, the "dark current" was rather low, in the line of a good battery should be able to handle for a couple of months.
    I don't think you have a thing to worry about, unless you reverse polarity trying to jump start it, then I think something bad could happen.
    I wouldn't disconnect it, you will lose all your radio presets, mileage history etc.
