Will these rims fit an 08 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Pings, Dec 30, 2007.
  1. Pings
    Pings Junior Member
    16
    Oroville, CA
    I was looking for a good set of very light-weight 15-17 inch rims for my pgk 2 08 Prius. After some of googleing, I came across the Buddy Club P1 Racing QF rim. Buddy Club market this rim as an "Ultra Lightweight Rim" to find out more check out the Buddy Club website, they also claim that the weight of this rim was 9.13 lbs!!!! while still maintaining structural rigidity. So after all that will these rims fit my car? Now would these get better MPG because there lighter than the stock Prius rims?
    http://www.buddyclub.us/buddyclub/p1rqf/p1rqf.html
  2. JaviNOS
    JaviNOS Mod Freak
    150
    Puerto Rico
    They look nice... I like 'em... But they also look expensive!
    If they come in a 5 x 100mm measurement they should fit a Prius...
  3. HSDP
    HSDP New Member
    36
    MA
    They will fit if the bolt pattern is the same and offsets are close. Check at www.tirerack.com to get that info. Buddyclub makes nice stuff. Those wheels are forged and should be very strong.
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    The OEM wheel specifications are PCD=100,# of holes=5, offset=45.
    15 inch standard:15X6JJ
    16 inch Turing:16X6JJ
    Anyway, Japanese hypermilers are saying the light weight wheels does not always show better MPG.
    Ken@Japan
  5. infogeek
    infogeek New Member
  6. Qlara
    Qlara New Member
    488
    Rim weight is one thing, but the tire you are going to pick and mount on will count much more.
    Some tires are heavier than others in same size......
  7. NavyScotty
    NavyScotty New Member
    Southeast Georgia
  8. 1r1shaz
    1r1shaz New Member
    22
    Arizona
    These wheels and many others like them have been around for quite sometime the tuner guys love lightweight wheels, but I think what Qlara said is the key to it all. You gotta factor in the weight of the tire and wheel combined. At one point in my life I owned a Matrix (One of many previous yota's) and everyone on those Forums was rolling lightweight wheels and tires. If I remember right Enkei & BBS made some of the more popular ones. Quick Question anyone ever tired using Lexus wheels on a Prius....say maybe the wheels off a IS250 or IS350?
  9. ken1784
    2,943
    1,380
    67
    Yokohama, JAPAN
    It looks IS250 uses 114.3mm PCD wheels. Prius uses 100mm PCD.
    Ken@Japan
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Thanks Ken, I wondered about that, because there is a set of Lexus IS250 wheels on ebay here
