Will Touch Up Paint Help Me Out?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by venom700, Mar 1, 2010.
  1. venom700
    venom700 Just call me Brian...
    196
    35
    Bethesda, MD
    I took a ding from my snow thrower when it skidded as I was clearing the driveway. Darn snow! Anyway, I know touch up paint won't by any means make the car look perfect, but all I care about is that the black plastic can no longer be seen (i.e. will it bond properly?).
    If you guys think it should work, and have any good tips for cleaning/application of the paint, all would be surely appreciated and I can follow up with pics.
      File size:
      73.9 KB
      765
      File size:
      77.7 KB
      675
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    On my Magnetic Gray I had mixed results repairing scratches so I'm not going to offer any repair tips. However, generally applying touchup paint sparingly ( a little bit several times as opposed to one big glop) will improve the appearance. I used the little bottle of Toyota touch up paint & ScratchX. Good luck.
    I have a scuff to play with when the weather gets warmer.
  3. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    In my experience...no. When you have a spot like that on a crease its going to be hard to get the touch-up paint to bond and fill anything in, since there is no lip for the paint to collect in like there is with a chip.
    I would find a detailer that does airbrush touch up and who does really good work...thats what you need for that...
  4. Johnny@crownautotrim.com
    [email protected] New Member
    Reno
    I had a similar plastic scratch on my Tacoma and all I did was remove the excess materiel with a razor blade and then used one of the touch up paint pens I sell and filled it in. Normal touch up paint will run, but the felt tip pens I sell will adhere much better. It will not look like new but at least the black plastic will not show.
    Thanks!
    -Johnny
  5. Johnny@crownautotrim.com
    Reno
    LOL,
    GM free is a good thing to be
  6. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    Touch up paint will make a huge difference. A black mark on silver car can be spotted from 25 feet away. If you cover it will touch up paint you will not be able to see the mark from more than 5 feet away.
    If you want it done right take it to a body shop. If you want it to look way better then it is use touch up paint.
  7. Postea
    Postea Junior Member
    San Mateo, CA
    You may want to try Bondo Bumper Repair Kit (No.280) This is sandable and flexible. It is two part mix and material comes in a double syringe. I would start by mixing a tiny amount and applying it with something small like a toothpick. Build up the layers and then sand it smooth without sanding the surrounding paint. Then use Toyota touchup paint. You may need a couple of coats. When completely dry, use a polishing compound in that area. It should be pretty invisible after that.
  8. venom700
    196
    35
    Bethesda, MD
    I decided to go with just the touchup paint for now. I put on one coat last night and just did another today. I will try some rubbing compound tomorrow to even things out and then wax it really well. I think this will do the job as far as keeping it from being noticed by the casual glance.
      File size:
      38.4 KB
      668
  9. BlizzardP
    BlizzardP New Member
    Boston Area
    I have what looks like a hit from a large rock on the bottom driver's side of my front bumper. Could you please tell me which touch-up paint you used? It seems to match well.
    thanks! :)
  10. mechanic
    mechanic New Member
    23
    all touch up paint are really the same, just look around online.
    You can just get the color code here Toyota Prius Touch Up Paint and order the paint at the dealership or online (online is cheaper, duh!)
    2 people like this.
  11. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Actually, with such an inexpensive item, it's probably cheaper to go to the dealer, since shipping charges would be a high % of the purchase price, and quickly offset any online price savings.
