Windsheild Washer Jets
Discussion in 'Gen 2 Prius Technical Discussion' started by Solarman44, May 21, 2008.
  1. Solarman44
    Solarman44 Junior Member
    78
    Largo, FL
    The far right side washer jet is spraying past the windsheld. Is there any tricks on adjusting the washers on the 2004 Prius? :confused:
  2. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    You might be able to put a pin in the nozzle and swivel it back into position. The pin sticking out of the nozzle will help you pinpoint where you need to aim it. :)
  3. Solarman44
    78
    Largo, FL
    GREAT idea, thanks for your help.
